The Void X ARGB Mini marks Kolink’s latest entry in their popular Void series. It is a Mid-Tower case with a unique aesthetic. A pair of triangular inlets in the front panel combine mirrors and ARGB LED lighting strips to create a curious ‘infinity’ effect.
The effect is yet further enhanced by the case’s dark black colour. Additionally the RGB LED strips can be easily adjusted for a variety of effects. Illumination, plus the rear fan, are controlled via 3-Pin 5VDG connector on the motherboard and a reset/RGB switch on the I/O panel can cycle through a variety of effects.
Embrace the void
In regard to internal capacity, the Void X, certainly lives up to its name. Despite having a Mid-Tower form factor, the interior is indeed void-like with ample space for components. There is support for dual radiators, vertical GPU mounting and even E-ATX Motherboards. Additionally Graphics cards up to 360mm can be fitted and there is space for CPU coolers up to 175mm and a full sized ATX PSUs.
In keeping with the Void X’s dark, sleek aesthetics, the interior is entirely in black, this even extends to the PSU shroud. Behind the shroud a pair of 3.5″ HDDs can be fitted, alternatively 2.5″ SSDs can be installed there, or besides the motherboard. The motherboard tray and PSU shroud feature plenty of inlets for easy cable management, with up to 24mm cable management space. Underneath the case is a removable dust filter suitable for a full sized ATX PSU.
Components can be kept cool too since there is room for 3 x 120mm or 2 x 140mm fans at the front and 2 x 120mm/140mm fans on the roof. Users are also free to install up to a 360mm radiator in the front, plus a 240mm radiator in the roof.
Last but by no means least, the I/O Panel features 2x USB3.0, 2 x USB2.0, HD Audio, Mic & a reset/RGB button.
