Laser vs optical mouse – is one truly better for gaming?
We’re taking a closer look at laser and optical mice, detailing their differences, pros and cons, along with determining which is better for gaming. As an added bonus, we’ve got some cheeky upgrades at the end so keep on reading for more!
What is a Laser Mouse?
A laser mouse utilises a laser diode to track mouse movements. Built with laser tracking technology, these mice boast enhanced tracking capability and heightened sensitivity.
Laser mice are a good choice for gamers and creatives thanks to their high-quality tracking, sensitivity, and DPI. You don’t require any special surface to use a laser mouse, they will work on most surfaces.
Pros and Cons of Laser Mice
Pros
- More precise compared to optical mice.
- Can reach a max DPI of up to 3000.
- Works on any surface.
- More models come with integrated RGB lighting for an added colourful flair.
Cons
- Typically, more expensive.
- Can be overly sensitive. Believe it or not, this can be a drawback for some. Laser mice can pick up very small details, which can affect your performance. For example, if you have a small dent in your desk, this may result in an increase in speed or even a slight cursor jitter.
What is an Optical Mouse?
Alternatively, an optical mouse harnesses an LED. Your mouse movements will be tracked by changes in reflected light. Any information collected is transformed into binary code, and later an action is performed on your monitor.
Optical mice are typically better suited for gamers who enjoy playing FPS titles because of their fast response times. However, they do require a non-reflective surface to work. For example, a glass table is not recommended for an optical gaming mouse.
Pros and Cons of Optical Mice
Pros
- Unlike traditional mechanical mice, there are no moving parts. Removes the need for regular cleaning.
- Good accuracy. When used with the correct surface, optical mice boast outstanding accuracy, making them perfect for gaming or creative workloads.
- Lightweight and portable. Makes them easier to carry around with you.
- Cheaper than a laser gaming mouse.
Cons
- Don’t work on reflective surfaces. If you are using a surface that is reflective, it won’t let the sensor function correctly. If you are, a mousepad is required for an optical mouse.
- The integrated LED light will glow, even when your PC is turned off. Not everyone wants a big red, blue, or green glow permanently illuminating their desk.
Laser vs Optical Mouse: Which is Better?
Laser vs optical – which is better for gaming? Ultimately, they both have their own pros and cons for gaming. However, which you choose all depends on your own individual preferences.
A laser mouse, with its heightened accuracy and high DPI, is perfect for gaming. All your mouse movements will be registered at ultra-fast speeds, giving you the edge during the heat of battle. You won’t have to worry about utilising a specific surface as laser mice will work seamlessly with any surface, with or without a mousepad.
However, this accuracy can be a drawback for some. The increased sensitivity means laser mice will pick even the smallest details. A dent in your desk that you never gave a second thought to may even result in a jittery cursor during the worst possible moments in-game.
Alternatively, an optical mouse is equally a great choice for gaming. These mice boast fast response times making them perfect for those who enjoy the fast-paced gameplay of FPS titles. Their lightweight construction makes them extremely portable and easy to carry around with you. Ideal for those who game on-the-go.
The major downside to optical mice is that they do require a specific surface to work on. If you are using a reflective surface, such as a glass table, the sensor within the optical mice won’t be able to work correctly. If you are going to be working or gaming from a reflective surface, you’ll need to purchase an additional mouse pad for your optical mouse.
Still struggling to decide which gaming mouse is right for your set-up? Check out our guide to gaming mice for more helpful advice on how to find the perfect mouse for you.
Looking to Upgrade Your Mouse Game?
Decided that an optical mouse is for you? At Overclockers UK, you can find plenty of high-quality optical gaming mice that are sure to give you that much-needed performance boost. We’ve picked out our top selections for you below, but if these don’t suit your aesthetic, you can browse all our gaming mice by clicking the button.
Glorious Model D Black Optical Gaming Mouse
- Optical gaming mouse
- Pixart PMW 3360 sensor with a max DPI of up to 12,000
- 1000Hz polling rate
- Ergonomic shape
- Integrated RGB lighting
Ducky Feather Black and White Kalih USB Optical Gaming Mouse
- USB connectivity
- PixArt PMW 3389 sensor with a max DPI of up to 16,000
- Kalih switches rated for 50 million clicks
- Lightweight construction of only 65g
Laser vs Optical Mouse – Which Did You Go For?
Laser vs optical – which one did you go for? Let us know which one and why in the comments.
