With cutting-edge wireless performance, passive noise control, and 30-hour battery life, the only choice you need to make is which game you’ll play first. The H3PRO Hybrid headset is designed for the demanding gamer that accepts no compromises in their wireless gaming needs—constructed with cutting edge wireless technology that ensures secure lag-free transmission of audio cues via dongle for instant in-game reactions. What’s more, simultaneous Bluetooth connectivity allows you to pair your phone for hands-free calling.
Enhanced noise cancellation
Designed with a closed acoustic structure, that eliminates high frequencies alongside a built-in ANC slider to remove low frequencies, you’re guaranteed complete immersion in games. EPOS engineered audio delivers clarity, resolution, and precision alongside a deep bass response and crisp chat for mid-game strategy discussions.
Dual microphone technology with a one in the boom arm and a secondary in the ear cup improves the noise cancellation for voice pick-up. The enhanced noise cancellation and ANC are especially handy when on the go and the detachable boom arm adds versatility thanks to its magnetic connection allowing for effortless removal.
EPOS enhanced audio
EPOS headsets come with a range of audio enhancing software and hardware, including the EPOS gaming suite. Take complete control and enhance your audio experience in the suite. You can control your surround sound, adjust equalizer settings, and more. In the software, you can also configure the integrated smart button, choosing its actions when you single or double press. Audio mixing with simultaneous Bluetooth is possible with your wired gaming connections. With separate volume control over each stream, you can make a call or chat with your friends using a 3rd party app on your smartphone while gaming.
Lightweight and comfortable
Built from the ground up for comfort, the EPOS H3PRO Hybrid comes with exchangeable ergonomic ear pads shaped to conform to the ear. What’s more, the headset is constructed from lightweight materials, meaning you can game all night long without a sore neck. The built-in, stainless-steel slider in the headband and hinged ear cups allow you to easily find a comfortable position.
On-the-fly controls, including the built-in volume wheel in the right ear cup, allow you to take complete control; and make quick adjustments mid-game. Finally, the detachable microphone features a lift-to-mute system enabling you to quickly silence yourself and stop embarrassing situations. Whether it’s accepting a cup of tea or a private conversation.
Available to Pre-Order
If you’re ready for next-generation wireless audio you can pre-order the EPOS H3PRO Hybrid or check out the full EPOS line-up of premium audio headsets on the Overclockers UK store.
EPOS H3PRO Hybrid Headset
- Up to 30 hours of lag-free wireless gaming
- Dual microphone detachable boom arm
- Programmable smart button
- Enhanced Noice Cancellation
- Low-latency dongle
