Today gamers can customise their spaces in ways not possible just a few years ago. First came dedicated gaming chairs, such as those offered by noblechairs and Nitro Concepts, but now gamers can really make spaces their own thanks to floorpads, deskpads and even Gaming Desks. Gaming Desks have been so successful that the Dk-04 and Dk-05 are Lian Li’s second entry into the category (Nitro Concepts has also recently launched a new gaming desk too).
What makes Lian Li’s gaming desks unique is that they can hold entire an PC system (in fact the Dk-05 can hold two). This means that a Lian Li gaming desk is both an eye catching addition to your gaming environment and can be the basis for a gaming powerhouse.
Excellent engineering and design
With sleek lines, robust build quality and of course a tempered glass top panel, the Lian Li Dk-04 and Dk-05 have remarkable aesthetics. The tempered glass panel is a standout feature with the option to switch between transparent and opaque modes via a built in button. This means you can easily display all the components you have fitted inside the gaming desk or discretely conceal them if you prefer.
It is also possible to cycle through a variety of RGB LED lighting effects. A total of 7 modes are available and can be manually controlled via another button on the desk or the LEDs can be synced to the motherboard.
Hours of gaming thanks to ergonomic features
Lian Li have included several features to ensure their Gaming Desks are comfortable to use for extended periods. For instance it is possible to adjust the height according to user preference and assign specific user-defined heights to buttons mounted to the desk.
Overall then if you want a new and unique Gaming Desk the Lian Li Dk-04 and Dk-05 are for you!
