Lian Li DK07: The Ultimate PC Case Desk
Equip your set-up with the ultimate desk-station: the Lian Li DK07
The Lian Li DK07 is both an electric desk and a PC case, in one premium, modular package. Designed for gamers and professionals, this desk provides ample space to work from and support for a dual PC system. Does your desk suddenly sound inadequate? Same.
Lian Li DK07
With premium build materials and an intelligent modular design, the Lian Li DK07 is the ultimate desk-station. Everything about this desk is sleek, from its brush finish to the tempered glass panelling. Plus, it is packed with extra features on top of being a desk and PC case with dual system support.
Lian Li DK07X Desk Case
  • Adjustable electric desk
  • Dual-system PC case
  • Extensive cooling support
  • Wireless charging and USB hub
  • Two drawers
DK07: As a Desk
As a desk, the Lian Li DK07 provides a spacious platform – measuring 1480mm by 805mm. The frame and PC case extrusion are manufactured from aluminium, and the 2mm desktop panels feature a brushed finish. Between these is a 6mm tempered glass panel offering an incredible view of the hardware within. To provide additional support, there are leg stabilisers anchoring the PC extrusion to the desk legs. As a result, this desk can support up to 100kg in weight.
To enhance ergonomics, this desk is height adjustable. For convenience, the controls are electric, and the screen can be locked to prevent accidental adjustments caused by stray paws. (Lian Li gets it.) The DK07 can be adjusted in height incrementally anywhere between 676mm and 1162mm using the up/down arrows. The height can be displayed in either centimetres or inches, whichever is your preference. What’s more, you have the option to save three different height settings and seamlessly switch between them with the press of a button.
Lian Li DK07 low height
Lian Li DK07 full height
On top of this, the Lian Li DK07 has some great organisational features, including built-in cable clips throughout the PC case and a cable tray at the back of the desk. There will be no messy wiring drooping onto your floor! Plus, the two spacious drawers include removable trays that help prevent your bits and bobs from getting jumbled up.
Finally, there is a wireless charging pad that doubles up as a USB port. When depressed into the desk, you can charge your compatible devices wirelessly. Alternatively, it can extend from the desk to reveal a USB-C and USB Type-A port instead.
We love a versatile workspace!
Lian Li DK07 height controls
Lian Li DK07 USB hub
Single vs Dual System
The Lian Li DK07 is, however, more than just a desk. It features an aluminium extrusion that can support a single- or dual-system gaming PC. Clearly not doing anything by halves, here!
To achieve this, the Lian Li DK07 utilises an intelligent modular design, where motherboard trays and brackets fit seamlessly together to create the foundation for either type of gaming PC. There are two motherboard trays included with the Lian Li DK07, each supporting up to the E-ATX form factor (330mm max.). You can use just the one for a single system or lay them side-by-side to create a dual PC.
These trays feature a back panel with rotatable expansion slots, a fan mount, and space for the motherboard I/O. They also have modular cable concealing brackets that can be moved about to accommodate your hardware. (Please note, they cannot be used with E-ATX motherboards.)
In both single- and dual-system set-ups, there is 383mm clearance for GPUs. Thanks to the rotatable expansion slots, you can choose to mount the graphics card either horizontally or vertically (riser cable sold separately). For your power supplies, there are brackets located in the top left and right corners for ATX PSUs.
Lian Li DK07 single system
Lian Li DK07 dual system
Cooling and Storage
The modular design truly comes into its element with the cooling and storage hardware brackets. In a single system, you can utilise these to install up to seventeen fans or sixteen storage drives, whereas in a dual-system it’s twelve and fourteen, respectively.
Naturally, you can choose between what you install, creating a balance of airflow and storage capacity to suit your needs. The following table details where the brackets are and what they can hold. We also have images demonstrating the different set-ups (click to expand!).
PositionSingle SystemDual System
Left2 x 120mm fans2 x 120mm fans
(PSU bracket)
Top1 x 120mm fan1 x 120mm fan
1 x 120mm fan
Right2 x 120mm fans
(PSU bracket)
2 x 120mm fans
(PSU bracket)
Front2 x 3.5″ HDDs
2 x 3.5″ HDDs
2 x 3.5″ HDDs
2 x 3.5″ HDDs
Middle6 x 120mm or 4 x 140mm fans
Up to 1 x 480mm radiator
Up to 2 x 280mm radiators
6 x 3.5″ HDDs
6 x 3.5″ HDDs
Motherboard Tray Left3 x 120mm fans
Up to 360mm radiator
3 x 2.5″ SSDs
Pump / controllers
2 x 2.5″ SSDs
Motherboard Tray Right3 x 120mm fans
3 x 2.5″ SSDs
Pump / controllers
2 x 2.5″ SSDs
Your Next Desk-Station
Is your set-up in need of a Lian Li DK07? This versatile desk with PC case extrusion is now available to pre-order from Overclockers UK. Let us know in the comments if you’ll be picking one up!
Newsletter phone image
Stay Up to Date!
Keep your finger on the pulse for all things tech, by signing up to our Newsletter!
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
