Taiwanese manufacturer Lian Li is most well-known for their high quality aluminum cases but today they offer many accessories so gamers can have the complete premium package.
Their latest product, the GALAHAD, is an outstanding AiO (All-in-One) cooler. Primarily intended to enhance your system’s performance, it runs quiet and will also look great thanks to its integrated DRGB illumination.
![Lian Li GALAHAD cap view](https://img.overclockers.co.uk/media/image/ll_galahad_cap.png)
High performance features
The GALAHAD is available in two sizes (240 and 360mm) with both models having features designed to optimise your PC’s performance. For instance Lian Li have included a thick 27mm alimunium radiator as well as fans with specialised fins to generate high static pressure. The fans are also PWM-controlled and can spin between 800-190 rpms. Meanwhile a three chamber pump reduces turbulence and operates at a quiet 20dBA
![Lian Li GALAHAD radiator](https://img.overclockers.co.uk/media/image/ll_galahad_panel.png)
Amazing build quality with excellent illumination options
Not only can the GALHAD help you improve performance but it has been designed to be a stylish component. In addition to the two sizes available, this AiO cooler comes in black or white and has some strong design features. Digitally addressable RGB illumination is integrated on both the fans and pump chamber. These LEDs can be software controlled via a 3-pin RGB (5V) connector on your motherboard or via the included controller.
Another novel feature of the GALAHAD is a magnetic lid attached to the pump. This lets users reveal or conceal the Lian Li logo. In fact it is even possible to rotate it so that the logo is properly aligned!
As a whole then the Lian Li GALAHAD AiO cooler offers users a great way to enhance both their system’s cooling and aesthetics.
