The Lian Li Galahad range of coolers has just received an upgrade, with the release of the three new AiOs: the Galahad II Trinity ARGB, SL-INF, and Performance.
Whether you’re looking to build a new powerful gaming PC or upgrade your existing one with a stylish new cooler, you can’t go wrong with one of these impressive AIO coolers. Not only do these coolers feature new innovations in design, for improved thermal performance, they also boast gorgeous ARGB lighting.
Innovative AiO
With the Galahad II Trinity range of AiOs, Lian Li has pulled a couple of neat tricks out of their hat, helping these coolers to deliver outstanding thermal performance. For example, the pumps have received several modifications to improve the coolant flow rate. This includes a redesign of the fin stack on their contact plates. Each fin has been made both taller and wider, providing extra surface area for transferring heat to your coolant. Additionally, the fins are spread further apart, creating less water resistance, thus increasing the flow rate throughout the loop and reducing the chance for residue to build up over time.
The pump’s pathways have been straightened, as any corners in a loop create water resistance. Thus, by making the pathway as straight as possible, coolant can flow much quicker.
The radiators have also received some attention. Both the Galahad II Trinty ARGB and SL-INF models feature a 27mm thick radiator, which boasts twenty fins per inch, creating an ideal balance of surface area to air resistance. Meanwhile, the Performance model utilises a 32mm thick radiator with a double-wave fin design, which offers extra surface area for dissipating heat.
All three radiators employ an innovative design for their fittings. Instead of the standard 90-degree fitting found on most AiOs, the Lian Li Galahad II Trinity range utilises a unique 45-degree fitting. This connector has the ability to rotate through a full 360-degrees, which makes mounting the Galahad II Trinity radiators a much simpler task.
Exceptional Fans
To create the airflow through the radiators, Lian Li has utilised three different fans for each Galahad II Trinity AiO. These fans have been matched to their respective radiators, ensuring that optimum temperatures can be maintained.
The Trinity ARGB comes with pre-installed ARGB fans, that offer exceptional performance and beautiful RGB lighting on the fan blades. Each fan can produce an astounding 89.1CFM of airflow, at a static pressure of 3.66mmH2O.
The SL-INF, meanwhile, is equipped with gorgeous UNI FAN SL-INF fans. These fans provide an amazing airflow of 61.3CFM, with a static pressure of 2.66mmH2O. What makes them stand out is their stunning looks, as each fan showcases several dazzling infinity mirrors.
For the Performance, Lian Li has pre-installed their powerful LCP fans to the radiator, to offer the best cooling results straight out the box. The LCP fan blades flex less than those manufactured from standard plastics. This allows for a tighter tolerance between the edge of the blade and the frame, maximising surface area. Thanks to this, each fan can produce a maximum airflow of 108.29CFM, with a static pressure of 6.88mmH2O.
Top Tier Looks
No matter which Lian Li Galahad II Trinity model you choose, you’ll have an AiO that looks fantastic in any gaming PC. You don’t have to worry about any cable clutter making your build look untidy either, as each radiator offers a discrete location to hide the fan cables, which can then be routed alongside the pipes back to the pump.
Alongside this, each set of fans offers a distinct aesthetic. The Performance comes with all black fans with no integrated lighting, for a subtle aesthetic. However, you can add a splash of colour to with a Lian Li ARGB kit (sold separately). Meanwhile, the ARGB model is equipped with RGB fans that feature vivid lighting effects across the fan blades. Lastly, the SL-INF models come with fans that feature three stylish infinity mirrors, as well as extra lighting around the frame and blades.
All three models are linked by the beautiful CPU pump, which boasts a swappable cap. Included with each model are three caps, called Duo-Infinity, Dazzle, and Sink-Hole. Duo-Infinity prominently features an infinity mirror at its core, surrounded by a brushed aluminium housing. For the Dazzle cap, there are two vivid RGB diffusers for the core and the housing, with each being able to display separate colours. Lastly, the Sink-Hole combines Duo-Infinity with Dazzle, combining an infinity mirror core and an RGB diffuser housing.
Grab a Fantastic Cooler for Your Build Today
Grab yourself an awesome AiO CPU cooler today, with one of the fantastic Lian Li Galahad Trinity II models available at Overclockers UK.
Lian Li Galahad II Trinity ARGB
- Compatible with modern Intel and AMD CPUs
- High-performance fans
- Swappable CPU pump caps
- Single-wave radiator design
- Each to install
Lian Li Galahad II Trinity SL-INF
- Innovative 45-degree radiator fittings
- Improved water flow through the loop
- Proprietary daisy chain fans
- Whisper quiet operation
- Infinity mirror RGB lighting
Lian Li Galahad II Trinity Performance
- Double-wave radiator fins
- Noise optimised and performance modes for fans
- LCP fans
- In-built controller within CPU pump
- Pre-installed fans for the best performance out of the box
