The Lian Li O11 is a well-loved PC case series amongst gamers and PC enthusiasts. This innovative dual-chamber chassis was developed in collaboration with world-renowned German overclocker DER8AUR. The latest edition to the range is the Air Mini which is a compact version of the existing PC-O11 AIR. This chassis is ideal for building a high-end PC. The smaller footprint is optimised for great airflow and hardware compatibility. You can buy both the black and white variants at Overclockers UK or keep reading to learn more.
Top Features:
- Mesh front and top increases airflow and cooling.
- Support for full sized motherboards and large graphics cards.
- High quality construction and premium materials.
- Fine mesh prevents dust and makes cleaning easier.
- Comes with preinstalled PWM fans in matching colour for easy setup.
- Compact in size which makes it more suitable for smaller desks.
- Vertical GPU Support – bracket and riser cable sold separately
Create a beautiful PC with the Lian Li O11 Air Mini:
The Lian Li O11 has a minimalistic design that utilises premium materials for a high-quality finish. It’s a great case for showcasing hardware and there are two different variants to choose from. The black version creates a stealthy look with a premium brushed aluminium finish. Alternatively, the white chassis opts for a smooth powder coated finish with silver screws, white mesh and light grey rubber grommets.
![Lian Li O11 Mini Air storage](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/mini-AIR_0825_14-786x1024.jpg)
Additionally, This is also where the PSU and storage are concealed. The main chamber will display your best components and this case makes cable management a breeze.
There’s even space to vertically mount a triple-slot graphics card (bracket sold separately) where it can be displayed front and centre in the heart of your PC. Finally, there are excellent mounting options for installing a plethora of RGB fans. This will create an incredible light show. There’s is also space for LED strips and stand out AIO coolers.
![Lian Li O11 Air Mini compare](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/mini-AIR_0825_07.jpg)
The large tempered glass side panel allows an unobstructed view of internal components. In addition to this, the features on offer ensure building your PC is super simple. First, there is the dual-chambered design which offers plenty of room to hide all those unsightly cables behind the motherboard tray. The rubber grommets are placed to route through the essential power connectors. Next, the multiple tie points and the included Velcro straps are ideal for tying cables in place in the spacious second chamber. Ideal if you’re using extensions that can take up more space such as the RGB Lian Li Strimer.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/mini-AIR_0825_11.jpg)
![Lian Li O11 Air Mini components](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/mini-AIR_0825_10.jpg)
Space for powerful hardware and cooling in the Lian Li O11 Air Mini:
The O11 Mini Air has been designed and optimised for excellent airflow and hardware compatibility. This means you can install high-end components without worrying about high temperatures harming performance. The front, top and bottom panels are all mesh which lets more air in and out. This mesh also acts as a dust filter to stop build-up which can block airflow.
![Lian Li O11 Mini Airflow](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/mini-AIR_0825_06.jpg)
![Lian Li O11 Air Mini Mesh](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/mini-AIR_0825_03.jpg)
The bottom of the case even has a removable dust filter for easy cleaning. There is plenty of room for enthusiast-grade hardware in both air and AIO cooling setups. There are even several different configurations depending on your preferences. This versatility allows for up to 280mm radiators, large GPUs, tall CPU coolers and ATX motherboards.
The rear of the case also has space for up to 6 storage drives, perfect for large creative files and games. Overall the Lian Li O11 Air Mini is a great foundation for creating a powerful and compact PC with a clean and stylish aesthetic.
Where to buy the Lian Li O11 Mini Air
If you’ve fallen in love with the O11 Air Mini you can get both the black and white versions on the Overclockers UK website. Alternatively, if you’re still on the hunt for a new case or want to make some comparisons, check out our similar blog posts below:
Kolink brings attractive high-end features to the mass market
![Lian Li O11 Mini Air build](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/O11-Air-MINI-Build-2.jpg)
