Strap in Overclockers, Lian Li has partnered with Automobili Lamborghini to bring you the O11D EVO RGB Automobili Lamborghini. A limited-edition case that packs phenomenal gaming performance, with Italian supercar good looks!
Supercar Inspired Looks
Automobili Lamborghini supercars have been dream vehicles for millions of people around the world for decades. That’s because they know how to make something look pretty, whilst packing some real oomph under the bonnet. Now, they have teamed up with Lian Li to put the same practices into a PC case.
The Lian Li O11D EVO RGB Automobili Lamborghini boasts many stylish features inspired directly by Lamborghini supercars. The tempered glass front panel showcases the iconic Automobili Lamborghini bull logo, located in pride of place the same way a cars badge is displayed on its bonnet. At the back of the case, you can find a car dash style 5″ LCD screen that can display your CPU or GPU’s performance metrics.
In addition to this, the case features multiple panels manufactured from authentic carbon fiber. This lightweight yet super strong material delivers a distinct cross hatch aesthetic to the Lian Li O11D EVO RGB Automobili Lamborghini. You can enjoy this stylish material from almost any angle, as it is used on the front and top panels, as well as the feet and front I/O module.
Completing the Automobili Lamborghini look is a subtle hint of colour. Giallo Orion to be exact. This distinctive shade of yellow was first used for the Mercielago, and has since been closely connected to the brand. You can find touches of Giallo Orion in several areas of the Lian Li O11D EVO RGB Automobili Lamborghini, such as on the thumb screws of the chassis. Each of these features a Giallo Orion rubber washer, to protect the case from scuffing. Additionally, the buttons on the case also use Giallo Orion for their typeface. Finally, the two RGB strips are preset to light up with Giallo Orion Pantone when powered on.
Exceptional Performance
Having the looks won’t matter if this case doesn’t deliver on performance. The Lian Li O11D EVO RGB Automobili Lamborghini does that and more! As it is based upon the hugely popular O11D series of cases, this chassis boasts the features that enthusiasts have come to love. This includes the dual chamber design, where your prized hardware is proudly displayed in a large front compartment, whilst your PSU, storage drives, and excess cables are hidden away in a rear.
With this layout, the Lian Li O11D EVO RGB Automobili Lamborghini is able to offer excellent compatibility with modern gaming hardware. In fact, the main chamber is large enough that you can easily fit real chonky components, such as E-ATX motherboards, 455mm long GPUs, and tall CPU tower coolers.
Keeping that hardware cool is simple, as this case is perfect for either air or water cooling. In an air-cooling configuration, you can pair the CPU tower cooler with up to nine fans. Three 120mm or 140mm fans can be mounted to the top, bottom, and side of the Lian Li O11D EVO RGB Automobili Lamborghini. If you prefer water cooling, then the top of the case is suitable for mounting a radiator up to 420mm long. Meanwhile, both the bottom and side of the case can facilitate a 360mm rad. Plus, with all that space in the main chamber, you’ll have plenty of room for any pipes whether you opt for an AIO or custom water loop.
Spec it How you Want it
When you order a car, you’re given a list of options on how you’d like to customise it. Well, with the Lian Li O11D EVO RGB Automobili Lamborghini you can get hands-on yourself. This is thanks to the highly configurable layout of the case.
Many panels and components can be removed and replaced in different locations, for entirely new layouts. The motherboard, for example, can be moved to a higher or lower mode, offering different compatibility with cooling hardware. The I/O module can be installed in several locations, giving you perfect access no matter your gaming setup.
This case is so adjustable, that the entire layout can be reversed entirely. If you want to place your PC on the right-hand side of your desk, you can leave the layout as is, which looks spectacular when viewed from the left. Alternatively, if you’re going to place your computer to your left, then simply move a few panels and components around, and your PC can now be observed from the right. Thanks to this, no matter how you arrange your desktop battle station, you can proudly display your gaming PC in all its glory.
Are you Ready to Hit the GAS GAS GAS!?
Are you inspired to build a racing rig with the Lian Li O11D EVO RGB Automobili Lamborghini? Then you’ll need to grab yourself one before they run out! Stick on some Eurobeat, head on over to Overclockers UK, and get your order in.
- Limited run of 6498 PC case
- Lian Li O11D case designed in collaboration with Automobili Lamborghini
- Dual chamber layout
- Supports E-ATX motherboards
- 455mm GPU clearance
When do we expect to see this out of pre-order?
Hey,
Stock is expected by the end of July. If you haven’t already got your order in, we suggest racing ahead with your order as stock is limited and they’re going fast!
Hey, when do you think I will receive it if I pre-ordered it and I’m in the US?
Our customer support team is better equipped to answer this question. You can contact them here. We also have detailed delivery options here.
I ordered the other day, when will I receive it?
Stock is projected to land end of July
Ok but when will they get shipped and delivered to the customer
Our customer services team may have a better picture and answer to your questions. You can contact them here.
