Typically, manufacturers will offer different variants of their most popular cases to match the different requirements of their users. Some variants might optimise for airflow, while others might prioritise aesthetics or internal capacity for components. With the Odyssey X, however, Li Lian offers a case that can do it all!
The shape shifter
The Odyssey X offers a straightforward way for users to ‘transform’ the case to match their preferred configuration – way easier than turning that Optimus Prime you got for Christmas into a lorry for instance.
The Odyssey X has three modes: Dynamic, Dynamic-R(Rotate), and Performance. The default configuration is Dynamic, with the others easily accessible. Simply rotate the motherboard tray for the Dynamic-R mode or rotate the case itself 90 degrees for the Performance configuration. The table below summarises the different characteristics of each mode:
Mode | Attributes |
Dynamic![]() | – Default configuration – Supports two 360mm radiators – Bundled mounting bracket for tall water pumps |
Dynamic-R![]() | – Improved cooling for GPU – Access to the motherboard’s I/O from the top panel – Supports 480mm + 280mm radiators or 360mm + 360mm radiators |
Performance![]() | – Flip 90 degrees – Supports 480mm + 280mm radiators or 360mm + 360mm radiators – Bundled mounting bracket for tall water pumps can be fitted |
Lian Li really have thought through the Odyssey X’s design, so much so that even the i/o panel is modular so it can be adjusted for each configuration.
As PC enthusiasts have come to expect from Lian Li, the Odyssey X is made from high-end materials. It has been constructed from an anodised aluminium that has been sandblasted to achieve a premium finish. Indeed, in the Dynamic modes, users have two options for mounting the aluminium front panels, allowing for further aesthetic customisation.
Eye catching Accessories
Even the tinted tempered glass side panels impart a unique look since they are mounted in a novel dual configuration. As a result of its unique design, the Odyssey X has also been optimised for airflow with multiple openings and inlets promoting the circulation of air.
There is also great support for cable management, with multiple rubber grommets, pass through holes, and Velcro straps. There is also space for three 2.5″ or 3.5″ drives.
LIAN LI ODYSSEY X BIG TOWER – BLACK
- Transformable PC
- Three configurations
Designed with der8auer - Aluminium construction
- Excellent airflow properties
LIAN LI ODYSSEY X BIG TOWER – SILVER
- Transformable PC
