![8Pack Orion X2 Pro Banner](https://img.overclockers.co.uk/media/image/Lian-Li-Razer-category0.jpg)
A new chapter in the success story of the renowned Lian Li PC-O11 Dynamic case that was initially forged in a collaboration between Lian Li and Roman “der8auer” Hartung has finally arrived! Lian Li presents, together with Razer, the PC-O11 Dynamic “Razer Edition”. The versatile Midi-Tower has been upgraded to include awe-inspiring Chroma lighting as well as the impressive Razer logo.
A total of 86 RGB-LEDs have been built into the case, with 46 located in the front and 40 in the base. Thanks to Chroma support, the RGB-LEDs can be integrated into Razer’s ecosystem to enable synchronisation between mice, keyboards, cases and other devices via Razer Synapse 3. The end result is an inspiring range of colours and patterns. Gamers that have searched in vain for the perfect gaming setup will receive, in the form of the Lian Li PC-O11 Dynamic “Razer Edition”, a case whose looks are not merely aesthetically impressive, but that make a statement as well.
The Features of the Lian Li PC-O11D “Razer Edition” at a Glance:
- Razer logo, 86 RGB-LEDs with Chroma support
- Premium combination of aluminium, tempered glass and steel
- Space for motherboards with E-ATX-, ATX- or Micro-ATX form factors
- Ingenious dual-chamber design for optimum cable management
- Up to 4x 3,5″-HDDs & 2x 2,5″-SSDs
- Front panel with 2x USB 3.0 Type-A & 1x USB 3.1 Type-C
- Supports graphics cards up to 42 cm in length & CPU coolers up to 15,5 cm tall
- Space for up to three 360 mm radiators or nine 120 mm fans
- Supports two power supplies behind the motherboard
The broad dual-chamber design of the renowned Lian Li PC-O11 Dynamic remains unchanged. The customisable Midi-Tower complete with aluminium- and tempered glass elements offers a capacious interior for powerful gaming components, alongside plenty of options for excellent cable management as well as the straightforward installation of a wide array of custom watercooling hardware. Up to three 360 mm radiators or compatible fans can be installed simultaneously in order to keep even the fastest gaming systems icy cool. Overclockers will be particularly pleased to hear that a second power supply can even be installed, making the case the perfect choice for power-hungry overclocked systems.
In order to give users easy access, as well as allowing them to enjoy the breathtaking view of the high-end hardware they’ve installed, the left side and front of the case hold large tempered glass elements that can be removed without resorting to the use of tools. Cables can be routed through a multitude of rubberised pass-throughs to discretely disappear into the second compartment, making the interior incomparably sleek and tidy. Up to four graphics cards can be installed to fill the total of eight slots, each of which can be up to 42 cm in length.
