Are you in the market for new fans? Do you want them to look drop-dead gorgeous? With the new Lian Li SL-INF fans, you’ve found your perfect thermal solution: plenty of cooling and bold styling.
Powerful Performance
Let’s kick things off and talk about the capabilities of Lian Li’s UNI fan SL-INF first, which should get you hot under the collar.
Lian Li has packed some serious performance into the SL-INF fans. With their 140mm diameter, these fans can produce more airflow at lower speeds. This means that your computer will maintain peak efficiency while staying whisper quiet.
![Lian Li SL-INF black fan side profile](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/fan14B_inf_07-300x300.jpg)
So, let’s talk numbers. Thanks to the PWM control, an SL-INF fan can range in speed from as little as 200RPM to a phenomenal 1600RPM. At maximum speeds, the highly efficient blade design outputs an amazing airflow of 72.7 CFM while being able to maintain a static air pressure of 2.88mmH2O. As I said before, an SL-INF fan is whisper quiet, even at maximum speed it only reaches a noise level of 28dB(A).
SL-INF Fans Like to be Together
Let’s examine the remarkable daisy-chain design of the Lian Li SL-INF fans, before we move on to the sweet RGB information. What’s the most annoying part when you have multiple fans in your case? That’s right, those cables running here, there, and everywhere. You have to go through the hassle of routing them, securing them in place with cable ties, or stuffing them out of sight. Just makes you want to go to bed instead, doesn’t it?
The Lian Li SL-INF fans solve this issue. No more will you need a cable for every fan. With their unique interlocking design, you can control up to four fans using a single cable. That’s right, four fans, one cable! But what about up to six fans with two cables? Sounds unbelievable, right? Well, you better believe it, because it’s possible utilising the Lian Li SL-INF fans.
![Lian Li SL-INF white fan unpowered](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/fan14A_inf_01-300x300.jpg)
How does it work? That’s easy to answer. With the UNI fan design, the connectors are built directly into the frame. One side of the fan has contact pins while the other has pads. Simply slide two fans together, and the pins will contact the pads creating a connection. What’s more, the cable is reversible, meaning you can easily hide it no matter which way you install your fans.
![Lain Li SL-INF fan showing Lian Li logo](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/fan14B_inf_02-300x300.jpg)
Furthermore, the Lian Li SL-INF fans can be easily mounted in any position, without interfering with the fittings. All the mounting hardware is removable, from the cable to keylocks. Once you’ve decided upon your cooling layout, you can create the perfect fan configuration to complement the design and remove the extra fittings. This simplifies installation, even on a radiator.
SL-INF The Fans That Like to Show Off
Now for what you’ve all been waiting for, the RGB. We all love pretty lights; you can find them almost everywhere, from cases to keyboards. So, to stand out from the crowd, you need to do something special. Oh boy, has Lian Li done something special with the UNI fan SL-INF.
Each fan boasts some standard RGB lighting, located around the frame as well as circling the Lian Li logo on the back of the fan hub. The real showstoppers, however, are the infinity mirrors. That’s right mirrors, plural! The SL-INF features three of these spectacular lighting devices.
![Lian Li SL-INF white fan side profile](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/fan14A_inf_07-300x300.jpg)
The first mirror is located at the centre of the fan hub and features a design that produces the illusion of a deep well. This effect is created through the careful spacing of the mirrored layers, just 0.5mm apart. The second and third mirrors are positioned on the sides of the frame, not used for connectivity. Multiple SL-INF fans can be seamlessly connected for a truly mesmerising effect.
Now to control all this gorgeous RGB, you’ll need Lian Li’s powerful L-Connect 3 software. You can configure every aspect of your fan lighting, from assigning colours, brightness, and even effects. What’s more, this can be done either with individual fans or by linking several fans together for a unified aesthetic.
Get Closer to Infinity with an SL-INF fan
So why not take your gaming PC cooling and lighting one step closer to infinity with a Lian Li UNI fan SL-INF? Get your pre-order in today, so you can be blown away by their cooling capabilities and style.
![Lian Li SL-INF fan with packing](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/fan14B_inf_06-300x300.jpg)
Lian Li UNI Fan SL-INF 140mm
- 140mm PWM fan
- Unique daisy-chain design
- High performance of 72.7 CFM with a static pressure of 2.88mmH2O
- Whisper quiet operation of just 28dB(A)
- Stunning infinity mirror RGB
