The Taiwan-based Lian Li is amongst the most renowned PC case manufacturers. They apply that same commitment to quality across the range of products they offer, including the new ST120 fans.
Coming in packs of three, with classic black or white variants, each fan features 12 addressable RGB LEDs per fan, which enable impressive illumination effects. Also included are a fan hub and RGB controller to make switching between illumination effects simple.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/02/黑3顆-2-RGB-1024x577.jpg)
Good things come in threes
The SL120 fans offer a great mix of design and performance. Their effective speed is a maximum of 1,900 rpm. With up to 32 dB(A) under full load, they remain quiet even with 117.5 m³/h airflow and 2.6 mmH2O static pressure at full speed.
The build quality is equally excellent with fluid dynamic bearings to ensure quiet operation and enhanced durability. Due to the reduced friction loss, higher speeds can be achieved when compared to conventional fans with the same power consumption. The enclosed fan hub is connected to the power supply unit via SATA power cable and to the motherboard via 4-pin PWM. Up to six Lian Li ST120 fans can be controlled via software.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/02/白3_2-1024x577.jpg)
Unlimited control
Each fan has 12 digitally addressable RGB LEDs and a dedicated RGB controller is included in the pack. This allows for easy control of illumination effects and modes.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/02/DSC_0393_2-1024x936.jpg)
