The Lian Li Strimer 24-Pin RGB motherboard cable enables users to give their motherboard’s power supply spectacular lighting. Thanks to twelve individually controllable RGB-LEDs, every visible wire receives its own individual colours, meaning the interior of your PC will enjoy some seriously vibrant lighting effects. The effects can either be controlled by means of a compatible motherboard with a digital 3-pin RGB header, or using the controller that comes included.
The Lian Li Strimer 24-Pin RGB Motherboard Cable at a Glance:
- Innovative extension cable with addressable RGB lighting
- Includes controller with 10 lighting effects like breathing, comet etc.
- Compatible with motherboards offering a digital 3-pin RGB header and ASUS Aura Sync Addressable
- Premium white sleeving for super vibrant colours
Stylish Extension Cable with Digital RGB Lighting
Developed in conjunction with overclocking champion der8auer, this cable comes braided in white to ensure the colours you choose are incredibly vibrant. The 24-pin ATX extension cable extends the 24-pin plug of any standard ATX power supply to work with the 24-pin connection on your motherboard.
The illuminated cables are organised together with cable combs and the cable itself consists of addressable RGB-LEDs. Thanks to the included controller, users may switch between ten different lighting modes as well as changing the speed and brightness.
If it is connected with a compatible 3-pin digital RGB header, the Strimer can be conveniently adjusted via Aura Sync Software. This also allows the lighting to be synchronised with other compatible components.
