Have you been looking for a unique case to build your dream gaming PC? Then Lian Li has got you covered with the stylish O11 Vision Chrome. Boasting the same outstanding features as the original O11 Vision, this new model comes with a gorgeous new look and mirror finish on its triple tempered glass panels.
![Lian Li Vision Chrome featured image](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Lian-Li-O11-Vision-Chrome-Square-1024x1024.jpg)
Distinctive Looks
The Lian Li O11 Vision Chrome is a special edition chassis designed by both Lian Li and PCMR. As such, it boasts many of the same innovative concepts as the original O11 Vision, including the dual chamber design, three tempered glass panels, and no supporting struts.
![Lian Li O11 Vision Chrome jointly developed with PCMR](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Vision-PCMR-1024x1024.jpg)
However, the O11 Vision Chrome has had some careful attention paid to how it looks, making it the ideal centrepiece for your gaming setup. The tempered glass panels aren’t just transparent, not even smoked, they’ve been made into one-way mirrors.
But why would you want this? Any light produced in your case can escape, whilst everything else is masked. Just imagine a gaming PC fully equipped with multiple pieces of RGB hardware, such as fans, CPU blocks, GPUs, RAM, and even cables. All that lighting will seem to hang in mid-air in the O11 Vision for a truly distinct aesthetic. It also helps to hide all manners of building mishaps. Who will ever notice if you’ve routed cables in all the wrong places if they can’t see them? (Just don’t pass them over your RGB lighting, though!)
![RGB shining through the mirror finish glass panels of the O11 Vision Chrome](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Vision-RGB-300x300.jpg)
Same Stunning Case Design
Aside from its distinct new look, the Lian Li O11 Vision Chrome is still the phenomenal case that the original models were. You’ll be able to build a true powerhouse gaming PC, as the main chamber provides ample room for installing modern gaming hardware. The motherboard tray can be removed, allowing for the easy installation of core components, including the motherboard, CPU, RAM, air cooler, and even your GPU.
![Main chamber of a Lian Li o11 Vision Chrome](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Vision-Main-Chamber-300x300.jpg)
What’s more, there is plenty of space for larger components. Have you got a high-end E-ATX motherboard? If it’s 280mm wide or under, it’ll fit. A large GPU? The O11 Vision Chrome has clearance for 455mm long cards, so no problem. A fan of air cooling? Well, with 167mm clearance, slap a tower cooler in and keep your CPU at optimum temperatures. Want to go for a custom water-cooling solution? There are options for mounting multiple radiators up to 360mm long and space for seven fans, go crazy.
And that’s just the main chamber! The second chamber also has plenty of room for hardware and all your cables. In this compartment, you can mount up to five storage drives. Three 2.5″ SSDs go on a removable cable management bar, and there is a drive cage that can accommodate either two 3.5″ HDDs or 2.5″ SSDs. Alongside this, the O11 Vision Chrome has space for a ATX power supply up to 220mm long. The mounting point for the PSU extends 15mm from the back of the chassis, which provides extra room for cable management.
Speaking of which, keeping your cables tidy is easy with the Lian Li O11 Vision Chrome, thanks to two dual-layer cable clips. They help to create clean runs for both your bulky and delicate wiring.
A Reflection of Your Taste
Will you be grabbing the beautiful Lian Li O11 Vision Chrome? Then get your order in today at Overclockers UK. Are you prepared to catch yourself in its reflection every day? Let us know in the comment section below.
Lian Li O11 Vision Chrome PC Case
- Mid-tower case
- Triple mirror finish tempered glass panels
- Supports E-ATX motherboards (280mm max)
- GPU clearance of 455mm
- Mount up to three radiators simultaneously
![A Lian Li o11 Vision Chrome](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/Lian-Li-O11-Vision-Chrome-300x300.jpg)
