The PC-O11 Dynamic Midi-Tower was built by Lian Li in cooperation with overclocking guru Roman “der8auer” Hartung to be perfect for overclockers. Capable of housing multiple 360 mm radiators, the case has been built from the ground up for extensive water cooling. Thanks to the case’s optimised airflow design, multiple fans can be installed in order to keep even the highest end hardware cool. The case is available in both elegant black steel as well as stylish white along with a tempered glass side panel and elegant aluminium elements.
![Lian Li PC-O11 Midi-Tower](https://img.overclockers.co.uk/media/image/GELI_807_01_BLOG.jpg)
![Lian Li PC-O11 Midi-Tower](https://img.overclockers.co.uk/media/image/GELI_808_04_BLOG.jpg)
The Features of the Lian Li PC-O11 Dynamic Midi-Tower:
- Elegant combination of aluminium, tempered glass and steel
- Space for E-ATX-, ATX- or Micro-ATX form factor motherboards
- Smart dual-chamber design
- 4x 2,5″ SDDs & 2x 3,5″ HDDs
- Front panel with 2x USB 3.0 Type A ports & 1x USB 3.1 Type C
- Compatible with graphics cards up to 42 cm in length
- Space for up to three 360 mm radiators
- Up to nine 120 mm fans possible
- Space for two power supplies
Perfect for Exhibiting Your Stylish Water Cooling Behind Tempered Glass
The Lian Li PC-O11 Dynamic Midi-Tower is equipped using 8 mm steel alonside a tinted, tempered glass side panel. Lian Li takes things one step further and has also furnished the left chamber of the ATX case with a brushed aluminium andt tempered glass front. In terms of mounting options for AiO- or custom water cooling, the case offers the possibility of installing up to three 360 mm radiators at once: One in the top, one on the bottom and one next to the motherboard. Those who prefer traditional air cooling will enjoy the possibility of installing up to nine 120 mm fans and one 155 mm high CPU cooler into this Midi-Tower.
The Lian Li PC-O11 Dynamic Midi-Tower stands slightly elevated atop rubberised steel feet, meaning that cool air can push through the bottom of the case – which is conveniently kitted out with dust filters. Thanks to the ingenious design, Lian Li utilises the ‘chimney’ principle to ensure warm air climbs to the top of the case and escapes through the roof, which also comes conveniently kitted out with dust filters. Two additional dust filters cover both perforated grills in the right hand side. The elegant Lian Li PC-O11 Dynamic Midi-Tower is not just the dictionary definition of beautiful, but it also pulls no punches when it comes to compatibility with the very latest and greatest of PC gaming hardware. Hardware enthusiasts will, without a shadow of a doubt, be very keen to cool to pair their case with similarly stunning custom loop cooling.
