![Glorious PC Race Model O-](https://img.overclockers.co.uk/media/image/Teaser-EN-Category-Glorious-PC-Gaming-Race-Model-O-minus-_blog.jpg)
Glorious PC Race Model O- Available Now to Pre-Order!
First deliveries expected from mid-September 2019.
The Glorious PC Gaming Race Model O- Gaming Mouse is, like its bigger sibling, a professional gaming mouse with a premium quality optical sensor from Pixart with six buttons that offers an ultra-precise tracking resolution of up to 12 000 DPI. What is particularly striking about it is the top of the Model O-, which is distinguished by its use of an attractive honeycomb design. This helps reduce the weight of the mouse by a significant degree to just 58 grams. Moreover, it helps ensure gamers benefit from cool and dry palms when the pressure is in. That’s not all, the RGB lighting of the mouse puts it centre stage, showing off its inner workings. The durability of the Glorious PC Gaming Race Model O- Gaming Mouse is bolstered by the use of ultra-reliable Omron switches. Needless to say, no corners are cut on the sensor either – with its ability to track at up to 50G acceleration.
The Features of the Glorious PC Gaming Race Model O- Gaming Mouse at a Glance:
- Precise tournament-grade gaming mouse with ergonomic honeycomb design
- Ambidextrous design, six programmable buttons
- Ultra-precise 12 000 DPI PixArt optical sensor
- 1000 Hertz Polling rate and 1ms response time
- Designed to support up to 50G of acceleration
- Super low friction mouse feet and flexible cable
- RGB-LED lighting
The special feature of the Glorious PC Gaming Race Model O- Gaming Mouse lies in its honeycomb design located on top and underneath. They help lower the total weight of the mouse by a significant margin, while also lending the mouse not just a unique appearance, but also allowing users to enjoy a view of its inner workings – which are in turn illuminated by means of customisable RGB-LED lighting. The added benefit of this design is also that it helps your palms stay dry and cool when the pressure is on.
The shape is optimised for ambidextrous operation, meaning that the hand is able to rest on the mouse in a natural position that minimises undue stress on the fingers when activating buttons and prevents unnecessary movement. Extended gaming sessions are no challenge thanks to its ergonomic implementation either. Amidst all these innovations, Glorious PC Race prioritises its light weight design for maximum comfort.
The mouse is designed from the ground up to cope with lightning-fast movements. As such, the Teflon glides are a smart design choice, meaning that whatever the mouse surface, the mouse remains more than capable of providing a smooth experience. Additionally, the braided cable offers a pleasing combination of durability, flexibility and low weight to the extent that you might even be forgiven for checking you didn’t just buy a wireless mouse by accident. All in all, the Glorious PC Gaming Race Model O- Gaming Mouse represents a superb choice for any serious gamer.
