If there is one thing I can say with confidence, it’s that noblechairs is a well-loved brand of gaming chairs. Winning multiple awards, noblechairs have brought you amazing comfort in a range of materials and special edition chairs, such as the ESO and Real Madrid chairs. Expanding on their premium repertoire, noblechairs now have a fabric gaming chair available in every model. Marvel at the noblechairs TX Series!
Premium Fabric Upholstery
In the past, noblechairs have been upholstered in leather, PU leather, or hybrid PU leather. The TX series utilises the fabric seen on the HERO ST Limited Edition gaming chair and brings it to all three models. Whilst it may be a new fabric, this upholstery bears the same quality standard as the other chairs. It’s breathable, durable, and supremely comfortable.
The subtle colour scheme is called Anthracite. A dark grey with a complimenting brushed effect, this fabric will seamlessly blend into your gaming environment. Delightfully soft to the touch, the upholstery is reinforced by a poly-blend material to lend extra durability to the chair.
Plus, with its highly breathable nature, the fabric TX series will keep you fresh during summer gaming sessions – something we really need right now!
noblechairs HERO TX Gaming Chair
Features |
Largest gaming chair in the range |
Breathable fabric upholstery |
Highly durable stainless steel frame |
Full lumbar support |
Backrest tilts through 35 degrees |
Premium build quality |
Machine assembled and stiched |
Includes head and lumbar pillows |
The HERO is the largest of the noblechairs range. With its pronounced wings and deep seat, it can support up to 150kg in weight. Use on either soft or hard flooring, the 60mm nylon-core casters feature a polyurethane coating which helps them to glide over most surfaces. Providing a stable and sturdy foundation is the 5-point base and stainless steel frame. You can enjoy long term gaming comfort with the noblechairs HERO TX Gaming Chair under your desk.
noblechairs EPIC TX Gaming Chair
Features |
Ergonomic gaming chair with wings |
Soft to the touch fabric upholstery |
Subtle, brushed grey colouring |
5-point base with nylon-core casters |
4D armrests |
Highly stable stainless steel frame |
Rocker mechanism with 11 degrees of movement |
Also sporting wings, the EPIC chair is more streamlined than the HERO, able to support up to 120kg. It still provides excellent support from work right through to play. The rocker mechanism has 11 degrees of movement, whilst the 4D armrests cover four directions of adjustment. Like with every model, you can tailor the noblechairs EPIC TX Gaming Chair to suit you perfectly.
noblechairs ICON TX Gaming Chair
Features |
Reinforced fabric upholstery |
Powder-coated aluminium base |
Deform-resistant cold foam padding |
Stylish Anthracite colour scheme |
Rounded headrest |
Iconic noblechairs branding |
Adjustable height settings |
Supports up to 150kg |
A little different to the other models, the ICON chair does not have wings and the headrest is completely rounded. Never fear, for it still meets the impeccable comfort standards as the rest of the range. Like the HERO, this gaming chair can support up to 150kg and is a supreme chair to game from. Putting the noblechairs ICON TX Gaming Chair at your battle station is an iconic choice.
noble Is As noble Does
noblechairs define premium. It’s in their name, their gaming chairs are noble. With deform-resistant cold foam holding its shape, amazing lumbar support, and certification for office use, these gaming chairs are the pinnacle of comfort. I’m wondering if we should start calling them gaming thrones.
Whether you go EPIC, HERO, or ICON, each of these chairs features a rocker mechanism and a backrest that can be angled from 90 through to 135 degrees. The overall height can be adjusted with the Safety Class 4 gas lift. Plus, with the 4D armrests, you can position them to the exact position for bringing you peak comfort. You can sit back, relax, and enjoy your gaming session.
The cherry atop this noble pie, included with the chair, is both a velour head and lumbar pillow. These attach easily onto your gaming with the adjustable band, meaning you can place them anywhere upon the backrest. Elevate your comfort even higher and experience support like never before. Filled with memory foam, these pillows will mould to fit you. Just imagine the naps you could have!
Get Yours Now
All three of these chairs are available for pre-order now on the Overclockers UK website. Pick from the HERO, EPIC, ICON, or all three!
- Fabric upholstery with poly-blend reinforcement
- Full lumbar support
- 5-point base with 60mm casters
- Supports up to 150kg
- 4D armrests
- Fabric upholstery on winged gaming chair
- Deform-resistant cold foam padding
- Velour memory foam pillow
- Supports up to 120kg
- Fabric upholstery in Anthracite
- Rounded headrest
- Fully adjustable ergonomics
- Safety Class 4 gas lift
Did you like this article?
noblechairs LEGEND Series: November 2022
New from noblechairs is their LEGEND series, which includes an exclusive TX Gaming Chair. Utilising the same premium breathable fabric as the TX range, this gaming chair boasts exceptional comfort with superior ergonomics. The TX edition is complete with a stylish brushed anthracite grey that will effortlessly fit into any aesthetic.
For an in-depth look at the TX edition and all of the other chairs in the noblechairs LEGEND series, take a look at our blog article!
