Lian Li’s popular Galahad AiO cooler has received an upgrade. Now with Lian Li UNI FAN SL fans included, this water-cooling loop is incredibly efficient and stylish to boot. They have it all, multi-chamber technology, sophisticated RGB lighting, and even a bracket for 12th Gen Intel compatibility. Plus, there are four models to choose from! Pick between black or white, and 240mm or 360mm models. That is some spicy stuff right there. Check these AiO coolers out.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/12/Twitter-PT-LianLi-Galahad-UNI-FAN-SL-1024x585.png)
M.C.T. and Efficient Cooling
The whole point of water-cooling loops is to efficiently and effectively maintain your gaming PC’s temperature, and the Lian Li Galahad AiO UNI FAN SL Edition delivers this in spades. The radiators are either 240mm or 360mm long, depending on the model you choose, and are stuffed with 20mm, folded fins. This massively increases the surface area for the heat to dissipate through, making for an incredibly streamlined process.
Manufactured from aluminium, the Lian Li Galahad AiO is afforded amazing heat conductive properties as well as being highly durable. Further optimising performance, the CPU pump utilises innovative Multi-Chamber Technology (M.C.T.). This three-chamber design unifies the component, combining the standard, connecting, and cold plate chambers. As a result, this configuration allows the cold and hot coolant to flow separately, thus reducing friction and increasing heat transfer.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/11/galahad-04-01_0.jpg)
The extra cherry on top? M.C.T. helps to prevent leaks and serves as protection even if the CPU block is damaged. Lian Li have covered every base with the Galahad AiO.
UNI FAN SL
Including the Lian Li UNI FAN SL 120mm fans is a game-changer. Utterly boosting thermal performance, these PWM fans can operate between speeds of 800 to 1900RPM, allowing you to adjust them as the workload dictates. Low load? Slow those speeds and enjoy the quiet performance. Gaming at max resolution and frame rate on the new AAA title? Boost fan speeds and never worry about throttling. With a maximum of 58.54 CFM airflow and static pressure of 2.54mmH2O, these are high-performance fans and an excellent addition to the Galahad AiO Cooler.
Do check out our dedicated post on them back when they launched, to learn more about these amazing fans.
![Lian Li UNI FAN SL120](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/11/lian-li-uni-fan-sl120mm.jpg)
RGB and L-Connect
Not only does this AiO cooler have incredible thermal performance but it looks lush as it efficiently cools your gaming PC. In part, this is down to the 32 LEDs per UNI FAN SL. Sixteen LEDs grace the top and bottom of the fan frame, each addressable utilising Lian Li’s intuitive L-Connect software. With this application, you can control the fans, as well as adjust the RGB LED colours, effects, brightness, and even direction. You can create some truly incredible light shows as the Lian Li Galahad AiO keeps your gaming PC operating at optimum temperature. Alternatively, you can synchronise with the software package compatible with your motherboard, for one-stop-shop access to everything you need.
In addition to the 32 LEDs per fan, the CPU block features lighting complete with an infinity effect. The aluminium cap is magnetic and easy to remove, allowing you to choose from two stylish aesthetics for your CPU block. To finish, the aluminium housing has been sandblasted for a smooth and sleek look.
![Lian Li Galahad 360 AiO Cooler UNI FAN SL Edition black](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/11/lian-li-galahad-360-black.jpg)
Extensive Compatibility
Lastly, the Lian Li Galahad AiO Cooler UNI FAN SL Edition has extensive compatibility with Intel sockets and AMD’s AM4. See the list for full compatibility options:
![Lian Li Galahad 240 AiO Cooler UNI FAN SL Edition white](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/11/lian-li-galahad-240-white.jpg)
- Intel LGA 115X
- Intel LGA 1366
- Intel LGA 775
- Intel LGA 1200
- Intel LGA 2011
- Intel LGA 2066
- AMD AM4
Additionally, for those of you rocking 12th Gen Intel processors, included within the contents is a bracket to make this cooler compatible with LGA 1700. I told you Lian Li had every base covered
Upgrade Now
If reading this has left you wanting more, then you are in luck. The Lian Li Galahad AiO Cooler UNI FAN SL Edition is available now to pre-order at Overclockers UK. Treat yourself to an early Christmas gift.
- Closed water cooling loop
- 2 x UNI FAN SL 120mm fans
- RGB lighting with 32 LEDs per fan
- Includes bracket for LGA 1700
- Available in black or white
![Lian Li Galahad 240 AiO Cooler UNI FAN SL Edition black](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/11/lian-li-galahad-240-black.jpg)
![Lian Li Galahad 360 AiO Cooler UNI FAN SL Edition white](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/11/lian-li-galahad-3060-white.jpg)
- Pre-filled water cooling loop
- Magnetic cap for two stylish looks
- Extensive compatibility with Intel sockets
- RGB lighting configured through L-Connect
