Kolink is a manufacturer known for creating high quality PC cases and related accessories at reasonable price points.
The Kolink Citadel is no exception. This Micro-ATX case ensures optimal airflow due to its mesh front panel and bundled 120mm PWM fans (three 120mm ARGB PWM fans in the case of the ARGB model and two black 120mm PWM fans in the standard model).
![Kolink Citadel multi case view](https://img.overclockers.co.uk/media/image/kolink_citadel_rgb_multi.png)
Awesome aesthetics
The ARGB variant also includes a RGB controller and a remote to quickly and easily adjust their illumination settings. There is also the option for adjustments to be made directly by the motherboard via a 3-Pin 5VDG connector. As a result of this illumination the Kolink Citadel has an impressive aesthetic. Both models also have tempered glass side panels so users can display any components they’ve mounted inside the Citadel.
![Kolink Citadel interior view](https://img.overclockers.co.uk/media/image/kolink_citadel_rgb_interior.png)
Space for all your components
Indeed there is plenty of room in the Citadel for all the components you need to make a powerful gaming PC. For instance two 3.5″ HDDs or 2.5″ SSDs can be fitted into a bundled drive cage included and a CPU cooler up to 19cm in height can be installed.
The Kolink Citadel is a great value package and will easily become the centre piece of your gaming setup.
