The case specialists at Phanteks have expanded their popular Enthoo Pro series with two new models sporting tempered glass. Apart from the usual slim and black version, Phanteks has also introduced a special edition with a white interior and Halos RGB fan frames. Both new models blend a range of features we have come to expect from Phanteks with some stunning visual highlights.
Thanks to the open view of the interior of the Midi-Tower, modders will be able to make the most of LED strips and lighting effects as well as showing off custom watercooling loops. The Enthoo Pro is also ideal for watercooling as it offers extensive compatibility with radiators and pumps. The tempered glass edition also comes with two pre-installed 140 mm fans included. In the Special Edition there is a 140 mm fan along with two 120 mm fans mounted in the front, and these are even equipped with Halos RGB fan frames. And as if that wasn’t enough, the case even offers room for large E-ATX format motherboards.
Enjoy the slim, timeless design of the renowned Enthoo series with brushed-aluminium look and angular design. Special installation points and interior mounting solutions make the Pro the dream of all watercooling enthusiasts. The case also comes with an extensive array of ingenious additions like radiator and pump mountings, massive removable dust filters in the front, roof and floor, pre-installed fans and great cable management options.
A Detailed Look at the Features:
- Premium Full-ATX tower with stylish tempered glass
- Designed for E-ATX or SSI-CEB servers and Micro-ATX motherboards
- Space for up to four large radiators for extensive watercooling options
- Space for Six internal 3,5″- or 2,5″ and modular HDD cages
- Additional options for four further 2,5″ drives
- Three external 5,25″ bays for optical drives and controllers
- I/O Panel with 2x USB 3.0 and 2x USB 2.0 as well as Audio In/out & LED control
- Comprehensive, sophisticated cable management
- Front and rear fans for optimal airflow
Special Edition Extras:
- Stunning white interior
- Two front fans with Halos RGB fan frames
>>> To the Phanteks Enthoo Pro Tempered Glass Editions at Overclockers! <<<
(click here)
