Phanteks has expanded their range of PC cable extension sets with new attractive colour combinations to offer case modders a safe and simple option for customising their system. These premium cable sets are designed from the ground up to make for a visually striking power supply cable and their varied and patterned textile sleeves give the interior of any system a fresh and individual look. Thanks to the multitude of colour combinations they blend perfectly into almost any colour scheme and the cable combs bundled in with the cables also guarantee an easy installation to ensure a flawless aesthetic.
The Features of Phanteks’ Extension Cable Sets at a Glance:
  • Varied colours and designs with lines and cross-shaped patterns
  • Set consists of 1x 24-Pin-, 1x 4+4-Pin- & 2x 6+2-Pin cables
  • Sleeves manufactured in fine polypropylene fabric – absolutely opaque and flexible
  • Black connectors for a clean aesthetic as well as a secure fit
  • Lengths of 500 mm for maximum reach
  • Practical and transparent cable combs for easy installation
Phanteks Extension Cable Combo Kit - Black/White
Phanteks Extension Cable Combo Kit - Black/Red
Unique and Tidy Look – Comes with New Colour Combinations and Designs!
The stylishly sleeved extension cables from Phanteks prove that design and functionality are not necessarily mutually exclusive. They are especially designed to upgrade the visuals of the PC’s interior by offering the perfectly tailored colour scheme. The unique feature of Phanteks cables lies in the use of polypropylene fabric for the sleeves. This is markedly higher-end when compared to the standard plastic versions, and they come very tightly threaded, offering complete opacity, as well as being soft to the touch. Furthermore every cable is individually sleeved. Additionally there are two 24-slot, four 8-slot- and two 6-slot cable combs bundled in. These allow you to perfectly orient each individual sleeve cable to ensure an incredibly sleek and tidy look.
Phanteks Extension Cable Combo Kit - Black/Blue
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
