The Features of the Kolink Nimbus at a Glance:
- Developed for motherboards up to ATX in form factor
- Large RGB-LED cut-out in the front section for optimised airflow
- Graphics cards up to 325 mm, CPU coolers up to 160 mm
- Tempered glass side
- One pre-installed 120 mm fan, total of six possible
- I/O Panel with a USB 3.0 Type A and two USB 2.0 ports, RGB-LED control
The Features of the Kolink Castle at a Glance:
- Designed for motherboards with up to an ATX form factor
- Graphics cards up to 350 mm, CPU coolers up to 160 mm
- Hinged side panel in tempered glass
- Two pre-installed 120 mm fans, total of six possible
- PSU shroud for a tidy interior
- I/O-Panel with a USB 3.0 Type A and two USB 2.0 ports
Kolink Nimbus: Elegant Exterior, Perfect Airflow
The Kolink Nimbus supports up to six 120mm- or four 140mm fans. A 120 mm fan is pre-installed in the back. At the front, either x3 120- or x2 140 mm fans can guide air in through the cut-out. Either x2 120- or x2 140 mm fans can be installed in the roof. Alternatively, 240mm radiators can be fitted at the front and top. Magnetic filters are present on the front, rear and bottom to ensure the interior remains dust-free. Motherboards up to ATX and graphics cards up to 325mm can be installed, with the tempered glass helping them to look their best.
Kolink Castle: Discreet, Spacious Interior
Despite the reserved exterior of the Kolink Castle, the interior offers all the more room for high-end hardware – emphasising the PC hardware. The TG side panel also allows for easy access to the motherboard (up to ATX) and the graphics card (up to 350mm). This can even be removed entirely if needed. The front allows up to three 120- or two 140mm fans, x1 120 mm fan comes pre-installed. An additional fan is located in back. Water cooling is also an alternative, with the case allowing users to utilise 240 mm radiators in the roof and front.
