Overclockers UK lists the very first range of Carbon Class gaming chairs from Nitro Concepts. The C80 Comfort, C80 Motion, and C80 Pure.
These are new gaming chairs, which combine high comfort with the neat aesthetics of racing car seats. Every Nitro Concepts gaming chair offers superb ergonomics with optimal adjustability and is ideally suited for gamers!
Every gamer, be it professional or not, spends hours sitting in front of his PC and requires an adequate seating accommodation in order to keep a healthy sitting posture and to achieve optimal results while playing. The Carbon Class C80 gaming chairs by Nitro Concepts are thus specifically catered to gamers and fit their needs perfectly. They are available in Black with a variety of accents, Black, Blue, Red, Orange, White or Green.
The C80’s are equipped with a sturdy steel frame mounted on top of a five-star-base made of nylon that features five smoothly running 50 mm casters. Further features encompass the 360-degree swivel rotation, the flexibly adjustable seat height via a safety class 4 gas lift along with the comfortable rocking mechanism, which allows for rocking the chairs up to 15 degrees.
The C80 gaming chairs’ are complemented by a breathable PU imitation leather cover with coloured accents and a PVC covering with a carbon look on the back side, while the softly cushioned armrests are also covered by high-grade PU faux leather. The entire cover has been made in accordance with strict quality guidelines, is cleanly sewn and checked, so that each single chair can fulfil our quality requirements. The thick upholstery is uniformly made from precision-moulded cold foam, which is manufactured while adhering to industrial standards to ensure outstanding quality and excellent workmanship.
The C80 Comfort series possesses an extra thick moulded cold foam upholstery that provides improved longevity and stability. The C80 Motion series distinguishes itself through extra high comfort thanks to an increased amount of space and folding armrests (90 degrees). The C80 Pure series features even further improved breathability thanks to its perforated seating surface cover. With great love for detail and utmost dedication, we have created unique gaming chairs that equally satisfy the demanding expectations of gamers and requirements for an office chair.
