Nitro concepts are a well-established gaming chair brand that has been making high quality and affordable gaming chairs ever since the companies launch in 2016. Each chair has been designed by passionate gamers who know poor comfort should never get in the way of a good gaming session. On the 14th of July, the company launched the brand new E250 series. As with all Nitro Concepts chairs, the E250 is great value for money, with vibrant aesthetics and great ergonomic properties.
There are four colours now available on the Overlockers website which you can check out by clicking the thumbnails below:
The E250 Series is crafted with high-quality materials such as breathable microfiber fabric and cold foam padding which have been chosen to create a sporty look but also help ensure the chair is comfortable for hours of gaming. These comfort features have been paired with a wide seating area and backrest so there’s plenty of space to move around.
The wide range of adjustability means you can change the seating position and armrests to suit you. The gas pressure spring enables the chair to be adjusted by up to 10cm in height. The seating angle can be moved thanks to an integrated rocker function that allows adjustment up to 14 degrees. The E250 series also has a backrest that can be adjusted by 45 degrees and flexible 2D armrests. The two included pillows for the neck and lumbar area complete the package. These features combined make the E250 a great choice for true gaming enthusiasts without breaking the bank. You can buy yours now for only £164.99.
