NVIDIA graphics cards have been fine-tuned for gamers and creators alike, harnessing plenty of integrated cutting-edge technology to boost your performance. Our series ‘Inside Look’ has been designed to showcase all this powerful hardware.
This blog post is all about DLSS and DLAA.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/06/Inside-Look-DLSS-and-DLAA-1024x1024.png)
What is NVIDIA DLSS?
DLSS, or Deep Learning Super Sampling, is NVIDIA’s own upscaling technology which has been designed to level up your in-game performance. Powered by AI, DLSS intelligently increases your frame rates, enhances image quality, and boosts your response times to optimise your games like never before.
DLSS harnesses the Tensor cores on your RTX GPU to render your games at a low resolution before inserting AI-generated frames to upscale your images to deliver photo-realistic visuals. Paired with built-in low latency tech and even Ray Reconstruction, DLSS can also notably reduce any lag, screen tearing, or image noise for enhanced in-game immersion.
There are three versions of DLSS:
- DLSS 2.0
- DLSS 3.0
- DLSS 3.5
We’ve covered each of them, showcasing why you want them for gaming.
DLSS 2.3: How to Get More FPS From Your GPU
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/04/DLSS-2.3-300x300.png)
DLSS 3.0: What is it and Why You Need it For Gaming
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/NVIDIA-DLSS-3.0-300x300.jpg)
DLSS 3.5: Why You Want it For Gaming
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/09/NVIDIA-AI-DLSS-3.5-300x300.jpg)
What is NVIDIA DLAA?
DLAA (Deep Learning Anti-Aliasing) utilises powerful AI to improve image quality by reducing any unwanted jagged edges. DLAA doesn’t involve any upscaling. Instead, your games are rendered at your native monitor resolution with the AI boosting visual quality and even your in-game FPS.
DLAA has been fine-tuned to reduce the effect of aliasing in popular titles. Aliasing is where diagonal lines on your display create a blocky jagged edge, otherwise known as the ‘staircase effect’. DLAA bridges the gap between individual pixels to deliver smoother edges for better more ‘polished’ in-game images.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/06/NVIDIA-DLAA.jpg)
DLSS vs DLAA – What’s the Difference?
Both DLSS and DLAA have the same foundation. They are designed to help enhance visual quality and FPS through AI to deliver more immersive gameplay in your favourite AAA titles. However, you can’t use them simultaneously, it’s one or the other.
If FPS isn’t high on your priority list and you are more concerned about image quality, DLAA is for you. Alternatively, DLSS is perfect for those looking to maximise their FPS and gaming output whilst also reaping the benefits of realistic visuals.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/pexels-3977908-PCGaming-1024x683.jpg)
DLSS and DLAA work on compatible RTX graphics cards without any specific resolution required. However, to get the most out of DLAA at your desired resolution, you’ll need to ensure you have the hardware to meet your demands.
How Can DLSS and DLAA Improve My Gaming?
NVIDIA DLSS and DLAA both allow you to get the most out of your favourite games, delivering you crystal-clear realistic visuals and heightened immersion. What makes DLSS and DLAA stand out is that you can decide which to use based on your needs, allowing you to further fine-tune your gaming to better suit your personal demands.
In Need of an Upgrade?
If you’re looking to utilise DLSS or DLAA but don’t have a PC to power this tech, you’re in luck! At Overclockers UK, we stock plenty of high-quality pre-built and configurable PCs that come equipped with an RTX compatible GPU.
We’ve got our top picks for you below, but you can also shop the full range by clicking the button.
Refract Gaming Jade Pre-Built PC
- Pre-built gaming PC
- Designed for mid-tier gaming and budding content creators
- Includes AMD Ryzen 7 7700 CPU and NVIDIA RTX 4060 Ti
- 32GB DDR5 RAM and 1TB M.2 SSD
- Customisable RGB lighting
![Refract Gaming Jade 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-jade-hero-300x300.jpg)
![OcUK Gaming Calcite - Intel Core i7 14700KF, RTX 4070Ti Super Pre-Built Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/ocuk-gaming-calcite-pre-built-pc-300x300.jpg)
OcUK Gaming Calcite Pre-Built PC
- Includes an Intel i7 14700KF CPU and NVIDIA RTX 4070 Ti Super GPU
OcUK Gaming Khopesh Configurable PC
- Configurable gaming PC
- Adjustable base hardware specification
- As standard includes an AMD Ryzen 7 7700X CPU and NVIDIA RTX 4070 Ti
- Up to 32GB DDR5 RAM
- Choice of secondary SSD
![OcUK Gaming Khopesh - AMD Ryzen 7 7700X, RTX 4070 Ti Super Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/05/ocuk-gaming-khopesh-2024-configurable-pc-300x300.jpg)
Read More in NVIDIA Inside Look
GeForce Now
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/GeForce-Now-300x300.jpg)
Reflex
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/NVIDIA-Reflex-300x300.jpg)
Encoder
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/NVIDIA-Encoder-300x300.jpg)
*Prices correct at time of writing and PC specs are subject to change.
