It’s no secret that our NVIDIA graphics cards come equipped with plenty of integrated tech to level up our gaming and productivity. Our ‘Inside Look’ series shines the light on many of these, but in this blog post we’re taking a closer look at NVIDIA G-Sync.
What is NVIDIA G-Sync?
G-Sync is NVIDIA’s own dedicated display technology that has been designed to deliver silky-smooth gaming courtesy of rapid response times and near-zero input lag.
How Does NVIDIA G-Sync Work?
NVIDIA G-Sync works by synchronising your monitor’s refresh rates with your GPU’s frame rate. For example, if your GPU performs at 50 FPS, G-Sync will swap your monitor’s refresh rate to 50Hz.
By automatically matching your refresh rate to your FPS, G-Sync can notably reduce input lag, display stutter, and screen tearing, delivering an uninterrupted gaming experience.
How Can NVIDIA G-Sync Improve My Performance?
NVIDIA G-Sync can have a huge impact on your gaming. By eliminating screen tearing and facilitating smoother performance, you can enjoy an optimised experience every time that fully immerses you in game. There’ll be no unwanted input lag or display stutter breaking up your immersion, delivering you that all-important competitive in-game edge.
Benefits of NVIDIA G-Sync for Gaming
We’ve rounded-up all the key benefits of NVIDIA G-Sync and why you want it for gaming below.
  • Sharper objects – objects in-game can appear sharper, offering you greater detail.
  • Scenes appear instantly – there’s no more waiting around for the next unexplored area to load. With G-Sync they load instantaneously.
  • Realistic colours – most monitors that support G-Sync also feature a high DCI-P3 colour gamut for true-to-life colour representation in-game.
  • Ultra-low latency.
  • Improved motion clarity – G-Sync monitors will also typically include ULMB (Ultra Low Motion Blur) to facilitate brighter images, no screen tearing, and improved clarity when images are moving on screen.
What Hardware Do I Need for NVIDIA G-Sync
NVIDIA G-Sync does have some hardware requirements, meaning you’ll need to make sure your PC meets the following to fully utilise G-Sync.
Recommended Specs
Windows 7-11
G-Sync compatible GPU – GeForce GTX 650 Ti Boost or higher
The latest NVIDIA GPU drivers
A G-Sync compatible monitor connected via DisplayPort.
NVIDIA G-Sync monitors can also be split into three tiers.
  • G-Sync Compatible
  • G-Sync
  • G-Sync Ultimate
Monitor Types Explained: Everything You Need to Know!
G-Sync Compatible
A G-Sync compatible monitor doesn’t include a dedicated NVIDIA G-Sync processor but have been certified by NVIDIA to deliver a high-quality variable refresh rate (VRR) for tear-free and stutter-free gaming.
G-Sync
A monitor with G-Sync support features a dedicated NVIDIA processor which has been designed to facilitate outstanding gaming performance with zero screen tearing, display stutter, or input lag. What’s more, the variable refresh rate (VRR) ensures stunning high-resolution images and responsiveness.
G-Sync Ultimate
G-Sync Ultimate monitors harness only the very best NVIDIA G-Sync processors along with HDR to deliver lifelike visuals, stunning image contrast, true-to-life colours, and seriously ultra-low latency gameplay. Everything you need to dominate your in-game enemies.
Not sure which tier your monitor falls under? Click the button below to see all NVIDIA compatible gaming monitors and their tiers.
Don’t Have the Hardware You Need for NVIDIA G-Sync?
Don’t have the right GPU or monitor for NVIDIA G-Sync? Why not treat yourself to one of the many tasty upgrades you can buy right now from Overclockers UK. We stock a huge range of both compatible GPUs and G-Sync gaming monitors.
Not sure where to start? We’ve highlighted some of our top picks, but you can also explore our full selection by clicking the relevant buttons.
ASUS GeForce RTX 4070 Super 12GB GDDR6X Graphics Card
  • NVIDIA RTX 40 Series
  • Ada Lovelace architecture
  • 7168 CUDA cores
  • 12GB GDDR6X included
Gigabyte GeForce RTX 4070 Ti Super 16GB GDDR6X Graphics Card
  • NVIDIA RTX 40 Series GPU
  • Built with Ada Lovelace
  • 8448 CUDA cores
  • 2640MHz boosted clock speed
  • 16GB GDDR6X VRAM
ASUS ROG Swift PG27AQN 27” Gaming Monitor
  • IPS panel
  • 2560 x 1440 resolution
  • 27’’ display
  • G-Sync support (with onboard G-Sync processor)
  • 1ms response time
MSI MAG 274QRF 27” Gaming Monitor
  • IPS panel
  • G-Sync certified (no dedicated processor)
  • 180Hz refresh rate
  • 1ms response time
AOC AG276QZD 27” Gaming Monitor
  • 27’’ gaming monitor
  • OLED panel
  • Support for NVIDIA G-Sync (with onboard G-Sync processor)
  • 0.03ms response time
Learn More in NVIDIA Inside Look
Do You Use NVIDIA G-Sync?
Do you use NVIDIA G-Sync? How has this display tech improved your gaming performance? Share your thoughts in the comments below.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
