First unveiled at Computex 2024, NVIDIA Project G-Assist promises to revolutionise the way we game. G-Assist has been fine-tuned to deliver real-time in-game assistance to help boost your performance. Say goodbye to getting stuck battling annoying bosses or solving complicated puzzles.
If you want to know more about NVIDIA Project G-Assist, then keep on reading because we’ve got all the key details you need to know.
What is NVIDIA Project G-Assist?
Whilst we all love games that feature highly developed vibrant worlds and plenty of intricate gameplay mechanics, they sure can be a challenge. Hours spent searching wikis and online forums for tips and advice on how to succeed is a sure way to break up our immersion. Enter NVIDIA G-Assist.
Compatible with RTX GPUs, G-Assist utilises a powerful AI to provide you with context-aware help and support as you play your favourite games.
How Does NVIDIA Project G-Assist Work?
The AI requires voice or text inputs from players, along with snapshots of the game window, to generate its answers. All the information is fed through AI vision models and large-scale game databases to provide you with a personalised response based on what’s happening on screen.
How Will NVIDIA Project G-Assist Enhance Your Gaming
NVIDIA’s demos with ARK: Survival Ascended and Cyberpunk 2077 showcase perfectly how G-Assist will change the way we game.
In-Game Advice
Activated by a simple hotkey or phrase, the integrated AI assistant can answer any question you might find yourself googling, ranging from queries about lore, items, to challenging bosses. Thanks to AI vision models, the assistant can also generate advice on what your next steps should be. Whether this is the best weapon to wield, where to find necessary materials, or if that big scary dinosaur is one you should avoid.
What’s more, as the AI assistant is contextually aware, you can also take advantage of personalised in-game recommendations. By analysing your playthrough, skill points, and even crafting menus, you’ll be given suggestions on what to pick next to further aid you in battle or secure those high-level items.
Performance Enhancements
In addition to these in-game prompts, NVIDIA Project G-Assist offers performance tuning. Finding the perfect settings to run your games can be a challenge with lots of tedious tweaking and testing. However, with a simple text prompt, G-Assist will analyse your hardware and automatically tune it to suit your performance demands.
By tracking your frame rates, power usage, PC latency, and more, the AI assistant can also give you helpful tips on how you can improve your experience even further, such as finding new ways to increase performance per watt or reduce power consumption.
If you want to see more about NVIDIA G-Assist in action, check out the video below.
Get Game Ready with NVIDIA G-Assist
To fully harness NVIDIA Project G-Assist, you’ll need to ensure you have an RTX-compatible GPU in your PC. Don’t have one? We’ve got plenty of NVIDIA RTX graphics cards available at Overclockers UK, with options to suit every budget and gamer.
Alternatively, if building your own computer isn’t your thing, we also stock a full range of powerful gaming PCs that come equipped with an NVIDIA GPU.
Refract Gaming Jade Pre-Built PC
- Pre-built gaming PC
- Designed for mid-tier gaming and budding content creators
- AMD Ryzen 7 7700 CPU and NVIDIA RTX 4060 Ti
- 32GB DDR5 RAM
- 1TB M.2 SSD
OcUK Gaming Karambit Configurable PC
- Configurable gaming PC
- Adjustable base hardware specification
- As standard includes an Intel i5 14600KF CPU and NVIDIA RTX 4060 Ti
- 16GB DDR4 RAM
- Selection of SSDs to choose from
Even More Great NVIDIA Tech
Looking for even more great NVIDIA tech to boost your gaming or creative workflows? Check out our highlights.
DLSS and DLAA
NVIDIA Ti vs Super vs Super Ti
NVIDIA Encoder (NVENC)
*Prices correct at time of writing and PC specs are subject to change.
