Graphics cards come in all shapes and sizes, meaning we’re often left scratching our heads at what dimensions we have or what case clearance we need, especially if you want to create a sleek, but space saving small form factor (SFF) powerhouse.
Thankfully, NVIDIA is set to revolutionise our SFF gaming PCs with their new line-up of SFF-ready GeForce GPUs. We’re here with all the details you need to know.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/NVIDIA-SFF-Ready-GPUs-1024x1024.png)
What are SFF Graphics Cards?
NVIDIA SFF GPUs will boast extensive compatibility with most modern-day SFF PC cases. It’ll be easy to spot if your GPU or case supports this form factor, with product pages being updated to mention ‘SFF-Ready Enthusiast GeForce Cards’ or ‘Compatible with SFF-Ready Enthusiast GeForce Cards’.
Whilst these GPUs may be small, they certainly pack the same punch as their counterparts. You’ll be able to find RTX 4070 or higher SFF-Ready GeForce GPUs. Each model will typically feature the same dimensions. This includes:
- 151mm maximum height including power cable bend radius
- 304mm maximum length
- 50mm or 2.5 slots maximum depth
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/NVIDIA-SFF-GPU-Measurements-Overclockers-UK-Blog-Feature-Image-Bottom-Text-Blog-1600x900Light-TextTwitter--1024x576.png)
All of which ensures you’ll have plenty of space and clearance within your PC case to facilitate natural airflow and optimum temperatures.
What Case Do You Need for an SFF GPU?
To fully utilise NVIDIA’s SFF-Ready GeForce GPUs, you’ll need to ensure you have a compatible case. SFF-Ready GeForce PC Cases feature plenty of space to accommodate these graphics cards and often include a bundled power connector and any other necessary accessories.
For your PC case to be compatible with an SFF GPU, it needs to meet a specific set of criteria. This includes:
- A total of 154.5mm clearance from either the motherboard or riser PCB to the side or top panel (depending on GPU orientation)
- Clearance of 312mm in length. This includes the GPU and any extenders.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/NVIDIA-SFF-Case-Measurements-Overclockers-UK-Blog-Feature-Image-Bottom-Text-Blog-1600x900Light-TextTwitter--1024x576.png)
Looking to Build Your Own?
Are you looking to build your very own space saving gaming PC? If so, you’re in luck for at Overclockers UK, you can find a select range of SFF-Ready GeForce GPUs and compatible cases. Check out our faves below!
ASUS GeForce RTX 4070 Ti Super ProArt OC 16GB GDDR6X Graphics Card
- NVIDIA RTX 40 Series
- 7680 CUDA cores
- 2670MHz boosted clock speed
- 16GB GDDR6X video memory
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/ASUSGeForce-RTX4070TiSuper-300x293.png)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/Zotac-RTX4070Super-300x245.png)
Zotac GeForce RTX 4070 Super 12GB GDDR6X Graphics Card
- 7168 CUDA cores
- 2475MHz boosted clock speed
- 12GB GDDR6X video memory
Fractal Design Terra Jade Mini-ITX PC Case
- Mini-ITX PC case
- Supports up to Mini-ITX motherboards and SFX-L or SFX PSUs
- 322mm GPU clearance
- Includes a PCIe 4.0 riser cable
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/07/FractalDesign-TerraMiniITX-300x256.png)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/12/kolink_rocket_v2_front-1-300x300.jpeg)
Kolink Rocket V2 Titanium Grey Mini-ITX PC Case
- Mini-ITX PC case
- Side panel ventilation holes for enhanced airflow
- 330mm GPU clearance
- PCIe 3.0 riser cable included
If our highlights don’t quite suit your vibes or gaming demands, you can see a full list of SFF GPUs and compatible cases by clicking the button.
Will You Be Upgrading to an NVIDIA SFF-Ready GPU?
Will you be upgrading your battle station to feature an NVIDIA SFF-Ready GPU? If so, be sure to share your thoughts with us in the comments.
If you need more convincing as to why you want a Mini-ITX PC – check out our ‘Anatomy Of’ article.
![Anatomy of a Mini-ITX Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/04/anatomy-of-a-mini-itx-pc-300x300.png)
