We are back with even more spicy Kolink products: the Kolink Unity Arena PC Case and Umbra X Fans.
![On the Arena Stage: Kolink Unity Arena and Umbra X](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/231212-KOLINK-ARENA-UMBRA-Eshot-1024x1024.jpg)
Are you in need of a proper showcase chassis? Perhaps a fan or three. This is the product drop for you. So, grab yourself a cuppa and a biscuit, as we take you through what we love about this case and fan.
What is Available?
From today, you can get the Kolink Unity Arena Mid Tower PC Case and Kolink Umbra X ARGB/PWM Fans, either in a single or triple pack.
Unity Arena PC Case
![Kolink Unity Arena PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/kolink-unity-arena-pc-case-top-down-300x300.jpg)
Umbra X 120mm Fan
![Kolink Umbra X 120mm Fan](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/kolink-umbra-x-120mm-fan-300x300.jpg)
The Kolink Unity Arena is a proper showcase chassis, with edge-to-edge tempered glass offering a panoramic view of your hardware. Pair that with the four pre-installed Kolink Umbra X fans, and you have an absolute showstopper on your hands. We’ll go into more detail on the fans later, but let me just say this for now: infinity mirror ARGB lighting. Juicy.
Hardware
We know it looks good, but how does the Kolink Unity Arena fare with hardware? Thanks to the spacious interior and intelligent layout, this mid tower PC case has extensive compatibility with the latest components currently available on the market. The backplate supports up to E-ATX motherboards and there are eight expansion slots for PCIe devices. Cheeky bonus: there are three additional vertical slots for mounting your GPU vertically, too (bracket sold separately).
Speaking of graphics cards, did somebody say 420mm clearance? That is the space you have to play with, which is more than enough for even the chonkiest NVIDIA RTX 40 Series GPU. Just think how good it will look mounted vertically, too.
To keep the interior looking clean and tidy, the Kolink Unity Arena includes a half PSU shroud. This accommodates ATX PS2 power supplies up to 180mm long. Finally, for your storage solution, there are four drive bays integrated in the design. Two can hold either 2.5” SSDs or 3.5” HDDs, whilst the other two are only for 2.5” drives.
![Kolink Unity Arena PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/kolink-unity-arena-pc-case-angled-300x300.jpg)
![Kolink Unity Arena PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/kolink-unity-arena-pc-case-io-300x300.jpg)
Cooling
Between the pre-installed fans and ventilation featured throughout the chassis, the Kolink Unity Arena has impressive cooling out of the box. Three fans are mounted to the motherboard backplate, using a reverse design so they can provide intake and keep their epic aesthetic. The final fan is installed on the rear panel. Of course, there are different fan configurations you can explore, with a maximum of nine supported at once. Prefer water-cooling? How about triple radiator support?
Here is a full breakdown of what each panel can accommodate:
Panel | Fans | Radiator | Pre-Installed Fan(s) |
Top | 3 x 120mm or 140mm | Up to 360mm | N/A |
Side | 3 x 120mm or 140mm | Up to 360mm | 3 x Umbra X 120mm |
PSU Shroud | 2 x 120mm | Up to 240mm | N/A |
Rear | 1 x 120mm or 140mm | Up to 140mm | 1 x Umbra X 120mm |
For the finishing touch, there is 189mm clearance for CPU coolers.
- Showcase with edge-to-edge glass
- 420mm GPU clearance
- Four pre-installed Kolink Umbra X fans
- Up to E-ATX motherboard
- Half PSU shroud
![Kolink Unity Arena PC Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/kolink-unity-arena-pc-case-300x300.jpg)
Kolink Umbra X
Now for the Kolink Umbra X fans. These pair high thermal performance with phenomenal aesthetics, and we are here for it. The fans are 120mm in diameter with a 28mm thickness and hydraulic bearing, to enhance durability. Having thicker fans means the blades can move more air at slower speeds, ultimately making the fans quieter. Want some numbers? Here you go. The maximum airflow is 61CFM, 2.46mmH2O for static pressure, all at a maximum volume of 24dBA. Plus, as they feature PWM control, you can adjust the fan speed between 600 and 1600RPM to best suit your computer’s current output.
Of course, the bit we’re all looking forward to is the ARGB lighting. The fan blades are illuminated, providing a vibrant glow as they spin, and the fan frame is accented with bold lines. But the real showstopper is the infinity mirror effect, featured on both the fan hub and frame edges. Stare into the colourful void and enjoy its many hues!
There are two Kolink Umbra X models available, a single and a triple pack. Naturally, the single pack includes one fan and all the necessary cables. The triple pack features three fans, the needed cables, and a controller hub with remote.
![Kolink Umbra X 120mm Fan Triple](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/12/kolink-umbra-x-120mm-fan-triple-300x300.jpg)
Kolink Umbra X ARGB/PWM 120mm Fan
- 28mm thick 120mm fan
- ARGB lighting with dual infinity mirror effects
- Fan speeds between 600 and 1600RPM
- Max volume of 24dBA
- Single or triple packs available
Enter the Unity Arena
Do these spicy Kolink products look like the missing piece of your gaming set-up? Both the Kolink Unity Arena and Umbra X are available to pre-order from Overclockers UK, now!
