The Overclockers UK Summer Sale is 🔥🔥. While there are plenty of spicy deals about, we’re taking a closer look at cooling hardware.
Cooling Hardware
With the summer sun shining down (we pray), it’s not just us that needs a little help keeping cool. Our gaming PCs work hard, and with that comes a little extra heat. To keep everything operating to temperature, we need cooling hardware.
Whether optimsing on natural airflow or crafting a fully custom-built water-cooling loop, these components keep our gaming hardware running happily. Plus, with whisper-quiet fans, you can concentrate on taking down monstrous foes in The Lands Between without interruption.
Top 5 Summer Sale Deals on Cooling Hardware
The Overclockers Summer Sale is packed with the hottest deals and spiciest savings. If you’re in the market for cooling components, then you’re in luck! We’ve rounded up five of the tastiest offers we have and put them all in one place for you. (I’ll take your thanks in the form of pick’n’mix.)
Aercool Eclipse ARGB 120mm Triple Fan Pack
- 3 x 120mm fans
- 12 addressable RGB LEDs
- 1000 RPM
- Controller included
- Save 40%
Jonsbo HX7280 Twin Tower Seven Heat Pipes CPU Cooler
- Tower CPU air cooler
- 1 x 120mm and 2 x 140mm PWM fans
- Up to 280W TDP
- Compatible with AMD and Intel
- Save 25%
Phanteks Glacier C370I Intel CPU Water Block
- CPU water-cooling block
- Acrylic cover with RGB LED
- Compatible with Intel CPUs
- Pure copper base plate
- Save 11%
Gigabyte AORUS WATERFORCE 240 ARGB Liquid AIO Performance CPU Cooler
- 240mm AIO cooler
- 2 x 120mm ARGB fans
- Optimised design for heat dissipation
- Compatible with Intel and AMD CPUs
- Save 20%
Phanteks Glacier G40 4090 MSI Graphics Card Water Block
- Water block designed for RTX 4090 GPUs by MSI
- Includes back plate
- Cast acrylic jetplate
- DRGB lighting
- Save 13%
Like to Know More?
Purchasing any upgrade takes a lot of thought and research. It’s not all about scoring the hottest deal – though it helps! We have plenty of content on the Overclockers UK blog to guide you through your decision and to the best product for your needs.
More Spicy Savings
We don’t just have deals on cooling hardware. Our Summer Sale is packed with savings on all kinds of hardware. Be sure to check out our full selection, and regularly, too! Some deals are limited time offers and others will be added throughout the duration. Don’t forget, you have until September 1st 2024 to bag yourself a bargain.
All deals are limited time offers. Price reductions were correct at the time of writing. Some deals have limited stock – once it’s gone, it’s gone.
