The next instalment of our ‘PC Modding with OcUK’ series is here! Today we’ll be showcasing all the different modding add-ons you can opt to include within your gaming PC.
Add-Ons
Our range of PC modding add-ons allows you to enhance your gaming computer’s performance and style. From fan guards or controllers, dust filters, and even remote controls to power your PC, we stock a wide range of add-ons. In fact, it’s time to explore them all in this dedicated PC Modding article.
Tool of the Trade
To install any of these add-ons, you’ll need the right tools. Thankfully, we have a blog post for that! To ensure you’re equipped with everything you need, take a look through our dedicated tools of the trade guide.
Fan Guards:
A fan guard provides a protective barrier around the spinning blades, whilst also improving airflow and reducing noise. They come in various designs and sizes, so be sure to choose one that fits your PC case and personal aesthetic.
OcUK 140mm Fan Guard:
  • 140mm fan guard
  • All black
Fan Controllers:
A fan controller grants you full access to your gaming PC’s cooling. These controllers allow you to manually control and adjust the speeds of your fans, depending on the task. During intensive workloads you can ramp up the speeds or alternatively, whilst idle, you can reduce them, to ensure a virtually silent operation.
Lamptron FC2 5.25’’ Bay Fan Controller:
  • Capable of controlling up to six channels
  • 45W each
  • Six 3-pin fan connectors
  • 5.25” bay
Dust Filters:
A dust filter is an essential aspect of any gaming PC. A build-up of dust can increase your system’s overall temperatures and even result in damage to your vital components. To prevent this, a high-quality dust filter blocks the intake to help keep your PC cool and quiet.
DEMCiflex 80mm Square Dust Filter:
  • 80mm
  • Square dust filters
  • Easy to install thanks to the magnetic frame
Card Readers:
With a card reader, you can effortlessly transfer data to and from a multitude of different devices, including cameras, mobile phones, and tablets. You can find both internal and external card readers with some models even serving as a USB hub, allowing you to connect a plethora of devices to your PC.
IcyBox Standard 5.25’’ USB 3.0 Multi Card Reader:
  • 5.25” multi-card reader
  • USB 3.0 connectivity
Hot Swap Rack Mounts:
A hot swap rack mount allows you to easily expand your PC’s storage capabilities. You can find multiple types of rack mounts with different sized bays to suit your storage needs.
IcyDock MB994SP-4S 4 x 2.5 to 5.225 SATA/SAS Backplane:
  • Supports up to 4 x 2.5” SATA SSDs
  • Up to 15mm in height
  • Status LED on the front for each device
Remote Control to Power PC:
Ever wanted to turn your PC on whilst you’re sat on the sofa? Well, you can with a handy PC power on remote control. Super simple to install, all you need is a spare internal USB header on your motherboard and that’s it. You can freely remotely turn on and restart your system.
Silverstone Remote to Power PC:
  • Remote to power on your PC
  • 2.4GHz frequency range
  • Up to 20 metres range
Learn More About PC Modding
PC Modding with OcUK: Custom Water-Cooling
Your Must-Have PC Add-Ons?
Have you modded your PC to include any of these add-ons? Which ones can’t you live without inside your PC? Let us know in the comments section below.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
