‘PC Modding with OcUK’ is back with our latest article in the series.
In this post, we’re taking a closer look at Lazer3D, a renowned PC manufacturer who has designed a range of products that are perfect for DIY PC building and modding.
Who is Lazer3D?
Lazer3D is a well known manufacturer of customisable PC cases and modding accessories. All of their products are designed with high airflow and space efficiency to ensure you get the best possible performance from your hardware.
Lazer3D Case Modding
Lazer3D has crafted a huge range of products for DIY case building and modding. You can find everything you need to customise your chassis, from panels, stands, case feet, I/O panels, to even storage drive mounts. All of which is available in a range of colours and finishes, such as wood or matte. You can create the ultimate DIY case that perfectly meets your desired aesthetic.
In addition to modding your PC, these components can also be used as replacements or upgrades to their line up configurable cases. This includes the Mini-ITX LZ7 and SSF HT5 series.
Lazer3D LZ7 Midnight Black Top Panel
- Top panel for LZ7
- SSF PC case
- Slotted ventilation for enhanced airflow
- Midnight Black
Lazer3D LZ7 Brushed Silver Case Feet
- Case feet for LZ7
- Brushed silver effect
Lazer3D LZ7 Moonlight White Case Stand
- Compatible with both LZ7 and extended LZ7
- Can be used to orientate your case both vertically and horizontally
- Improves airflow
- All-white design
- Available in four different colour variants
Do these not suit your needs or aesthetic? You can shop all of Lazer3D’s DIY PC case components by clicking the button below.
