We’re back with the next installment of our dedicated ‘PC Modding with OcUK’ series. First up, is a deep dive into all the necessary tools you need to successfully mod your PC.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/PC-Modding-Tools-of-the-Trade-1-1024x1024.jpg)
PC Modding
PC modding is the art of making cosmetic changes to your system’s hardware or chassis. You can opt for case LED lighting, noise dampening panels, or even painting your case. In fact, there are limitless mods you can make to your computer.
Must-Have PC Modding Tools
We have a range of dedicated tools designed to make PC modding even easier. This includes screwdriver sets, dust blowers, cleaning sprays, and much more.
We’ve included a few of the must-have tools down below.
Essential Toolkits:
iFixit Pro Tech Toolkit:
The iFixit Pro Tech Toolkit comes packed with all the essential tools you need to make PC modding a breeze! This includes a 64-bit driver kit, grounding strap, several different opening tools and picks, safe and cross-tweezers, various spatulas, and much more.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/iFixit-ProTech-291x300.png)
- Comes equipped with everything you need for PC modding, DIY, and repairing
- Includes a 64-bit driver kit, several different opening tools and picks, grounding straps, and much more.
iFixit Marlin Screwdriver Set:
The iFixit Marlin Screwdriver Set includes fifteen different essential fixed blade screwdrivers, perfect for all your DIY or PC modding projects. Each screwdriver in the kit features a precision tip, swivel top, and ergonomic rubberised handle for enhanced comfort. All your drivers are stored within a fabric tool roll that is easy to take with you anywhere.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/iFixit-Marlin-Screwdriverset.png)
- Complete screwdriver set
- Includes fifteen different essential fixed blade screwdrivers
- Stored within a fabric tool roll
iFixit Mako 64 Bit Driver Kit:
Armed with the iFixit Mako 64 Bit Driver Kit, you’ll have all the necessary tools you need to mod your PC. This complete kit includes a magnetic aluminium screwdriver with a ball-bearing rotary cap, along with sixty-four different bits. All of which are stored within a durable casing to keep them well protected when not in use.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/iFixit-Mako-64bitkit-300x260.png)
- Complete magnetic screwdriver kit
- Comes with sixty-four different bits
- Stored within a hard top case
Additional Modding Accessories:
iFixit Dust Blower:
PC modding can get dusty! Thankfully, with the iFixit Dust Blower any excess dust or dirt can be safely removed from your case and precious hardware. The precise nozzle means you easily access those hard to reach places, without damaging your components.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/iFixit-DustBlower-300x247.png)
- Must-have for removing dirt and dust
- The precise nozzle allows for easy reach in those hard to reach places
iFixit Screen Cleaning Spray:
Speaking of cleaning, another must-have tool is the iFixit Screen Cleaning Spray. This mild cleaning solution can be used on your displays and plastic housings, to help get them looking shiny and factory fresh once more.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/iFixit-Cleaningspray-281x300.png)
- 250ml cleaning solution
- Can be used on displays, mobiles, plastic housing, and much more
iFixit Foldable Anti-static Mat:
All your precious PC hardware is sensitive to electrostatic damage. The iFixit Foldable Anti-static Mat can help prevent this. The mat is grounded via two crocodile clips, one of which is connected to a spiral cable attached to an electrostatic bracelet. What’s more, thanks to its small form factor it can easily be folded up and transported.
You can opt to pair this anti-static mat with a wrist strap and sorting tray to help further protect all your vital hardware.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/05/iFixit-Foldableanti-staticmat.png)
- Anti-static mat
- Grounded via two crocodile clips connected to an electrostatic bracelet
- Portable – easy to fold up and take anywhere with you
Read More in ‘PC Modding with OcUK’
Custom Water-Cooling
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/03/PC-Modding-Custom-Water-Cooling-300x300.jpg)
Sleeved Cables
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/PC-Modding-Sleeved-Cables-300x300.jpg)
RGB
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/10/PC-Modding-RGB-300x300.jpg)
Your Must-Have PC Modding Tools?
If you’ve modded your PC, be sure to leave all your tool recommendations and top tips in the comments below.
