The latest generation of PCIe has arrived! PCIe 5.0 SSDs boast a suite of performance enhancing features, including notably faster read and write speeds.
If you’re looking to upgrade to a PCIe 5.0 SSD, then we’ve compiled everything you need to know into one handy post. We’ll be highlighting what exactly PCIe 5.0 is, how it compares to previous generations, and all the benefits it brings to gamers and creative professionals, alike.
What is PCIe 5.0?
PCIe 5.0 is the latest generation of SSD which has been redefined to include notably faster read and write speeds. Compared to previous generations, the bandwidth, frequency, and gigatransfer rates have all been doubled. PCIe 5.0 boasts 32Tps transfer speeds, up to 128GBps bandwidth, and a frequency of 32GHz.
PCIe 5.0 is compatible with the latest generation of hardware, including Intel 13th Gen and AMD Ryzen 7000 processors. However, PCIe 5.0 is also backward compatible. This means you don’t have to upgrade to a motherboard with a compatible PCIe 5.0 slot. You can still use a PCIe 5.0 SSD with a 4.0 M.2 slot. However, you won’t be able to truly take advantage of all the benefits PCIe 5.0 brings.
How will PCIe 5.0 Benefit…
Gamers:
Gamers can take advantage of a PCIe 5.0 SSD to enjoy blisteringly fast loading times in all their favourite games. You’ll never need to worry about pesky loading screens breaking up your immersion ever again.
Creatives:
For creative professionals high speed read and write rates are a must-have! You’ll be able to access and store all your data in seconds, with no input lag or latency limiting your performance.
Streamers:
Streamers can take advantage of a PCIe 5 SSD for ultra-fast data transfer speeds and loading times in game. You don’t need to worry about your live stream suffering from input lag or unwanted slow loading screens.
It’s Time to Upgrade to PCIe 5.0
Crucial T700 4TB PCIe 5.0 NVMe M.2 SSD:
Enjoy lightning-fast performance with the Crucial T700 4TB 5.0 M.2 SSD. With a storage capacity of up to 4TB, you’ll never need to worry about running out of precious storage space. There’ll be plenty for your expanding gaming library, creative projects, and much more. What’s more, with read and write speeds of up to 12,400/11,800MB/s, respectively, all your data will be stored and transferred in record time.
Thanks to integrated support for DirectStorage, this SSD can render any high-resolution textures up to 60% faster compared to traditional solid state drives. This is perfect for gamers and creative professionals looking to achieve maximum performance and multitasking. Lastly, to ensure temperatures remain at optimum levels, this SSD comes equipped with an integrated heatsink to effectively dissipate any excess heat. You can also opt for an SSD without the heatsink if you prefer.
- Storage capacity of up to 4TB
- 12,400MB/s read speed
- 11,8000MB/s write speed
You can also opt to shop the entire range of PCIe 5.0 SSDs by clicking the button below.
Have You Upgraded to PCIe 5.0?
Have you upgraded to a PCIe 5 SSD? Be sure to let us know your thoughts down below. Has it enhanced your gaming or creative performance?
