We’re back with more juicy Kolink goodies: three Kolink Unity PC cases and a Kolink Umbra Void Pro fan.
Like to prioritise airflow in your gaming PC? Perhaps you’re all about that RGB. Or maybe, you want an absolute showcase chassis. There is a Kolink Unity PC case for each of these needs, all sporting their own stunning aesthetics. If you’re more in the market for a thermal upgrade, we got you too, thanks to the Kolink Umbra Void Pro fan. It’s time to grab yourself a cuppa and the shopping list!
Today’s Line Up
In total, we have four Kolink goodies to showcase. First, there are the Kolink Unity Meshbay Performance and ARGB Edition PC cases, which mostly follow the same spec but are each fine-tuned for either airflow or lighting. Next up, we have the Kolink Unity Peak PC case, an absolute showcase with edge-to-edge glass panelling. Last, but most certainly not least, we have the Kolink Umbra Void Pro fan with stylish infinity mirror ARGB lighting effects.
Kolink Unity Meshbay ARGB
Kolink Unity Peak
Kolink Unity
These three Kolink Unity cases bear some great similarities, in regards to specs and what hardware they can support. In terms of aesthetics and airflow, though, each case is unique.
Meshbay Performance
The Kolink Unity Meshbay Performance Mid Tower PC Case sports a classic all-black finish, with mesh panelling on the front and side. Everything about this case has been optimised for phenomenal out-of-the-box cooling. This includes having three pre-installed Kolink PWM 120mm fans, two on the front and the third on the back.
Meshbay ARGB
Still curated for great natural airflow, the Kolink Unity Meshbay ARGB Mid Tower PC Case brings a splash of colour into the mix. This case features four pre-installed Kolink Umbra S ARGB/PWM 120mm fans, three on the front and the last on the rear. In addition to this, the Meshbay ARGB swaps out the side mesh panel for sliding tempered glass instead. You get the best of both worlds, a display for your hardware and efficient cooling!
Peak
The Kolink Unity Peak Mid Tower PC Case stands on its own. The edge-to-edge tempered glass panelling creates a panoramic view into your gaming PC, with the sliding function on the side pane affording easy access. Plus, the four pre-installed Kolink Umbra Void Pro ARGB/PWM 120mm fans bring style and cooling to the table. All in all, this is a pretty peak showcase. Geddit?
Shared Features
Being from the same series, these cases do bear some similarities. This mainly lies in their hardware support. To start with, these mid tower cases can all support Mini-ITX, Micro-ATX, or ATX motherboards and have seven expansion slots for PCIe devices. Even better, there are two vertical slots to accommodate a vertical mount for your GPU. (Kit sold separately.)
When it comes to your graphics card, there is an amazing 400mm clearance. Plenty of room for an NVIDIA RTX 40 Series GPU! Excuse me while I just picture an RTX 40 Series on display in the Unity Peak with all that RGB goodness. (What, I like rainbows.)
All three editions feature a half PSU shroud, keeping the interior sleek and tidy. This dedicated space can hold ATX power supplies between 150mm and 180mm. Finally, you can curate a storage solution that balances high-capacity drives with ultra-fast read and write speeds. There are four drive bays, two for 2.5” SSDs and another two for 3.5” HDDs. Tasty.
Cooling Support
As already seen with the pre-installed fans, a few differences lie in the Kolink Unity Series’ cooling hardware. This extends to the support provided. The below table breaks down what hardware each case can accommodate, where they mount, and if an ARGB fan controller is included.
Panel | Unity Meshbay Performance | Unity Meshbay ARGB | Unity Peak |
Front | 3 x 120mm / 140mm fans up to 360mm radiator | 3 x 120mm / 140mm fans up to 360mm radiator | N/A |
Top | 3 x 120mm / 140mm fans up to 360mm radiator | 3 x 120mm / 140mm fans up to 360mm radiator | 3 x 120mm / 140mm fans up to 360mm radiator |
Rear | 1 x 120mm fan up to 120mm radiator | 1 x 120mm fan up to 120mm radiator | 1 x 120mm fan up to 120mm radiator |
Motherboard Tray | N/A up to 240mm radiator | N/A up to 240mm radiator | 3 x 120mm / 140mm fans up to 240mm radiator |
PSU Shroud | 3 x 120mm fans N/A | 3 x 120mm fans N/A | 3 x 120mm fans N/A |
Controller | N/A | ARGB hub included | ARGB hub included |
Kolink Unity Meshbay Series PC Case
- Mid tower PC case
- 400mm GPU clearance and vertical mounting
- Mesh panelling and pre-installed fans
- Extensive cooling support
- Available in Performance and ARGB (pictured) models
Kolink Unity Peak PC Case
- Mid tower PC case
- Edge-to-edge tempered glass panelling
The eagle eyed among you may have noticed that the Kolink Umbra Void Pro Infinity Mirror ARGB PWM fans are included on the Kolink Unity Peak. Should the talk of infinity mirror effects and efficient cooling have piqued your interest, I am here to provide that all-important info.
These are 120mm fans, with a 25mm thick frame, and an evolution of the original Kolink Umbra Void fans. Naturally, there have been tweaks to the components to improve performance, whilst the addition of more ARGB lighting and infinity mirrors has certainly boosted their style!
Style and Substance
Starting with their cooling performance, the Kolink Umbra Void Pro utilises a hydraulic bearing and optimised fan design to produce a maximum airflow of 57.2CFM. Static pressure maxes at 2.1mmH2O and the loudest they go is 30dB. Typical noise levels are usually around 19.4dB, however. Thanks to intelligent PWM control, you can adjust fan speeds between 800 and 1800RPM, to best suit your gaming PC’s load.
Now, the Umbra Void Pro fans have ARGB lighting in spades and I am honestly here for it. The fans are illuminated, creating a vibrant glow as they spin. Surrounding them are lined details on the fan frame. The fan hub and frame edges are the true showstoppers, though. This is where the infinity mirror effect is used, creating an endless stream of lighting to gaze into!
Kolink Umbra Void Pro ARGB/PWM 120mm Fan
- 120mm fan, 25mm thick
- ARGB lighting with dual infinity mirror effect
- Hydraulic bearing
- 57.2CFM airflow and 2.1mmH2O static pressure
- Max noise level of 30dB
Time for an Upgrade
All three of the Kolink Unity cases and the Umbra Void Pro fan are available at Overclockers UK. Drop a comment below with your favourite of these cases!
