Personalise Your Play is back. This time, we want to illuminate your gaming PC and level up your aesthetics with glorious RGB and the TechForge DRGB Light Box.
With the TechForge DRGB Light Box, you can create stunning and synchronised effects across all your DRGB devices. Elevate your lighting from out-of-the-box effects to the full spectrum of colours in designs you can engineer yourself. Trust us, your gaming PC will never look better.
What is the TechForge DRGB Light Box?
The TechForge DRGB Light Box is packed with up to 90 DRGB LEDs, depending on the compatible model, and they are arranged in four channels. These can be individually addressed and even layered up, to create truly unique effects that are all your own. We really mean it when we say personalise your play!
The TechForge DRGB Light Box can be synchronised with all your existing DRGB devices and is compatible with most lighting software, making for easy integration. Plus, it is equipped with relative positioning and continuous effects. This means you can start an effect from one point of your gaming PC and watch it ripple across the light box and all your devices!
Enjoy bright and vibrant lighting, with stunning visual impact.
See the TechForge Light Boxes in Action!
Compatible Cases
We have TechForge DRGB Light Boxes built for a tasty selection of popular PC cases. Some light boxes will fit a few different cases, whilst most are designed for a specific series. Currently, we have models for the following PC cases:
- Corsair 4000D, 5000D, and 7000D in both black and white variants
- Phanteks Evolv, P600, G500, P400, G360A, XT View, NV5, and NV7 series, in both black and white variants
- Lian Li O11D / XL, O11D EVO / XL, and Lancool 216
- APNX C1
- ASUS ROG Strix Helios
- Fractal Design Define 7
Each model contains all the necessary accessories for installation, including providing the cables for connecting either via your motherboard or DRGB controller.
Please note, the Corsair light boxes require an iCUE adapter to fully utilise Corsair iCUE software. These can be purchased separately.
Personalise your play further, with custom printing on your noblechairs! Learn more about this amazing service and, frankly, ogle at some incredible designs in our dedicated blog!
How to Install the TechForge DRGB Light Box
The cherry on top of all this RGB goodness? The TechForge DRGB Light Box is heckin’ easy to install. Got to love it! Simply follow these instructions to get mind-boggling lighting in your gaming PC.
- Make sure your gaming PC is turned off and unplugged before removing the side panel.
- Carefully remove the TechForge DRGB Light Box and accessories from all packaging.
- Mount to the bottom of your PC case – being mindful of your components and airflow.
- Choose whether you want to connect to your motherboard or dedicated controller.
- If you’re connecting to the motherboard: plug the 3-pin DRGB cable into the DRGB header. If you’ve gone for the dedicated controller: connect using the dedicated 3-pin ARGB cable provided.
- To secure the light box in place, apply the included double-sided sticky tape to the underside of the device.
- Then, peel away the protective backing and firmly press the light box into place. These last two steps are optional but advised.
- Replace your case’s side panel and power up your PC – this is to check the connections are secure and your lighting is functional.
- Lighting effects can then be adjusted using your chosen compatible software.
- Stand back and enjoy the show!
TLDR; Watch How to Install a TechForge DRGB Light Box
Personalise Your Play Now!
Ready to level up your lighting? The TechForge DRGB Light Boxes are available at Overclockers UK, right now! We absolutely want to see your gaming PCs in all their RGB glory, so be sure to snap some pics and tag our socials – @OverclockersUK on Facebook, Instagram, X / Twitter, and TikTok.
- Easy to install DRGB light box
- Up to 90 DRGB LEDs
- Available for a range of popular PC cases
- Installation accessories included
- Level up your lighting!
