For the enthusiast who insists on only the most power-hungry of components in their system, comes this beast of a power supply. The Phanteks AMP 1000W performs like a reliable shire horse, keeping your system ticking over nicely, but it has the looks of a thoroughbred stallion. Featuring a gorgeous pure-white finish for both the case and cables, this is a PSU that can’t help but turn heads with its aesthetic.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/Phanteks-AMP-White-Feature-1024x1024.jpg)
Efficiency is key in a PSU
The Phanteks AMP 1000W White Edition is a powerful yet efficient PSU. In fact, it is 92% efficient at half load, leading it to be awarded an 80 Plus Gold rating. To achieve this efficiency, the AMP 1000 White uses an innovative design for power delivery. This includes using gold-plated high-current terminals, and a cable-free design for connecting the PCB to the backplate. Phanteks has been able to harness the physical properties of gold to reduce the electrical resistance through these circuits.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/Internals-of-AMP-1000W-1024x569.jpg)
Want your games to look mind-blowing with all that fancy ray tracing and AI technology? Well, you’re going to need a powerful GPU for that. Or perhaps you’ll want things like the latest innovations in memory and storage for better performance? For that, you’ll need a top-of-the-line CPU. These premium components come with demanding power requirements, but that’s where the Phanteks AMP 1000W White shines. With its 1000W power delivery, you’ll be able to build your dream machine and power it easily.
Substance and Style
We all know that one of the most important things when it comes to a proper gaming PC is the aesthetic. It’s all about showing off your sweet custom PC. So, a way forward is to obviously use a clean, crisp white aesthetic. That way, you’ll be able to show off your master building skills. Phanteks has you covered for this stylish build, thanks to the AMP 1000W White Edition. Both the unit and the modular cables come in a brilliant white finish.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/AMP-White-1000W-1024x569.jpg)
Now you want your PC to turn heads for the right reason. The looks, not for its being akin to a jet engine. The Phanteks AMP 1000W White helps to keep things quiet so you can concentrate on what’s important, your favourite game! With a hybrid control mode, the AMP 1000W can deliver up to 40% of its potential load without needing to run the fan for silent operation. Alongside this, the 120mm fan features fluid dynamic bearings, which cut down on the vibrations to provide near-silent operation.
Revolt PRO PSU Compatible
Here at Overclockers UK, we love Star Wars (check out the fantastic Boba Fett chair from noblechairs over at our store) and with the Revolt Pro Link System, all we can think about is Unlimited Power!! By simply linking the AMP 1000W White to a Phanteks Revolt Pro PSU, you can increase the output of your power delivery by double, maybe even triple, the amount available depending on what power supplies are used.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/AMP-White-1000W-Scope-of-Delivery-1024x569.jpg)
Alongside this increase in raw power, for even the most outrageous builds, the Revolt PRO Link system also should catch the eye of creators. For those who need a workstation that just can’t fail on them no matter what, having dual power supplies adds an extra layer of protection. If the unthinkable happens and a power surge occurs overloading one of your supplies, you’ll have a redundant PSU ready to run your workstation keeping your valuable data that much safer.
Grab yourself a True Powerhouse
So, if you’re thinking of upgrading your current PC or maybe going to build a new one with all the latest hardware. You’ll want plenty of headroom for power delivery, so why not pre-order a Phanteks AMP 1000W White over at Overclockers UK.
- 1000W PSU
- 80 Plus Gold Certified
- Fully Modular
- ATX Form Factor
- Temperature Controlled Fan Operation
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/AMP-White-1000W-with-box-300x167.jpg)
CLEARLY the Seasonic Focus (GX) platform. Explains the “beastly” performance. 🙂
