Update 1 – PHANTEKS Eclipse P400 Air Metal Mesh Front-Panel now available!
Original contribution – Optimized airflow: The PHANTEKS Eclipse P400 Air Midi-Tower
Update 1: PHANTEKS Eclipse P400 Air Metal Mesh Front Panel Now Available!
PHANTEKS now offers the metal mesh front panel used in the Eclipse P400A as a spare part. For example, in the case of damage, the front can be easily replaced. But the front panel is not only suitable for this purpose, it can also be mounted on the Eclipse P400 and Eclipse P400S to enable users’ cases to benefit from improved air supply.
Original article: Optimised Airflow: The PHANTEKS Eclipse P400 Air Midi-Tower
The cases of the Eclipse P400 Air Series have been designed with newcomers to the world of PC building in mind, while also providing an array of interesting features for experienced PC enthusiasts to enjoy – not least its excellent airflow, despite the sleek exterior. Because the front of the Eclipse P400 Air is made from a metal plate with a fine mesh grille, the case allows for unobstructed airflow while also keeping the interior free of dust. The advantage of this solution in comparison to the traditional combination of mesh and dust filters lies in the fact that air is more effectively exhausted through the rear of the case.
Furthermore, the sturdy mesh also adds a certain je ne sais quoi when it comes to aesthetics as well, particularly when some lighting is added to the interior. The Eclipse P400 Air is available in two variants, one with two pre-installed fans without RGB-LEDs but with fan controls on the I/O panel and one with three 120 mm RGB-LED fans plus an RGB controller on the I/O panel.
The Features of the PHANTEKS Eclipse P400 Air:
  • Premium Midi-Tower with tempered glass side panel
  • Two pre-installed 120 mm fans with speed control on the I/O panel
  • DRGB Version with three 120 mm RGB-LED fans and RGB controller on the I/O panel
  • Compatible with motherboards up to E-ATX
  • Metal front with mesh grille
  • 2x 2,5“ slots & 2x 2,5-/3,5” slots
  • Graphics cards up to 420 mm long
The new P400 Air Midi-Tower from the PHANTEKS Eclipse series impresses with ist looks, use of clean lines as well as the premium-quality yet somewhat ascetic design in white and black. The metal mesh grille adorning the front of the case along with the large tinted, tempered glass side window combine to make the case unquestionably high-end when it comes to appearances, and the LED lighting on the three pre-installed 120 mm fans on the front of the DRGB variants only serve to emphasise this.
For casual- and hardcore gamers alike, the PHANTEKS Eclipse P400 Air offers a great deal of versatility when it comes to installing high-end gaming hardware e.g graphics cards up to 420 mm in length and radiator mounts for AiO- and custom water cooling. The rear of the case allows for a 120 mm fan or equivalent radiator, while the front holds three 120 mm fans or two 140 mm fans. As an alternative to the fans, 280- or 360 mm radiators can be installed in the front. Needless to say, there’s more than enough space here to create the system of your dreams.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
