![Phanteks Glacier G30 STRIX blog header](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/11/phanteks_glacier_strix_g30-blog_header-1024x341.jpg)
At this point Phanteks’ ability to produce quality peripherals is on par with its ability to make cases. Now, with the G30 STRIX, the Dutch manufacturer updates their acclaimed Glacier line of water cooling accessories with a new waterblock and backplate designed for Asus ROG Strix RTX 3090/3080 GPUs.
![Phanteks Glacier G30 STRIX RGB illumination](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/11/phanteks_glacier_strix_g30-illumination-1024x1024.jpg)
Outstanding build quality
Though high performance GPUs have been design to manage tremendous computational loads they can still become extremely hot, which of course reduces their performance. A waterblock and backplate provide an ideal way to mount your GPU to your PC and integrate it into a liquid cooling setup.
The G30 STRIX offers the perfect way to add your Asus ROG Strix RTX 3090/3080 GPUs to a liquid cooling system. With waterblock and backplate available either separately or bundled together, the components are made from a combination of an aluminium cover, nickel-plated copper base, clear transparent Acrylic top and VITON sealing (which happens to be used in automotive and aerospace industries).
![Phanteks Glacier G30 STRIX RGB Liquid](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/11/phanteks_glacier_strix_g30-liquid-1024x1024.jpg)
Tremendous aesthetics with RGB integration
Not only should a waterblock enable users to securely mount their GPU to their PC but it should do so in a way that showcases the GPU at its best. Once again the G30 STRIX excels in this respect. Not only because of the afore mentioned high quality materials used in its construction but also because of its integrated D-RGB illumination. This can be synced with D-RGB accessories from Phanteks and compatible third-party D-RGB products. Indeed illumination effects are perfectly complemented by the black or chrome colours the G30 Strix comes in.
As a result your the GPU in your case will look just as good as the graphics its outputting!
