Premium gaming components need highly efficient cooling hardware. With our gaming PCs now featuring an Nvidia GeForce RTX 3090Ti or two, we need even more thermal power to keep everything running at peak. Enter Phanteks. Expanding on their much-loved Glacier range, they have created the Glacier G3090Ti Waterblocks for Asus, MSI, and Gigabyte graphics cards. Juicy.
![Phanteks Glacier G3090Ti Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/Phanteks-Glacier-g3090ti-1024x342.jpg.webp)
New Kids on the Water Block
There are three models in the Glacier G3090Ti range, each coming in two stylish colours. Pick from chrome or black, as you match the model of waterblock to the manufacturer of your graphics card. The models are compatible with either Asus, MSI, or Gigabyte graphics cards. Here are what each model is compatible with:
Glacier G3090Ti ASUS
![Phanteks Glacier G3090Ti ASUS Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-asus-blackbg.jpg.webp)
- ASUS ROG Strix LC GeForce RTX 3090 Ti
- ASUS ROG Strix LC GeForce RTX 3090 Ti OC Edition
- ASUS TUF Gaming GeForce RTX 3090 Ti 24GB
- ASUS TUF Gaming GeForce RTX 3090 Ti OC Edition 24GB
Glacier G3090Ti Gigabyte
![Phanteks Glacier G3090Ti Gigabyte Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-gigabyte-blackbg.jpg.webp)
- GIGABYTE AORUS GeForce RTX 3090 Ti XTREME WATERFORCE 24G
- GIGABYTE GeForce RTX 3090 Ti GAMING OC 24G
- GIGABYTE GeForce RTX 3090 Ti GAMING 24G
Glacier G3090Ti MSI
![Phanteks Glacier G3090Ti MSI Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-msi-blackbg.jpg.webp)
- MSI GeForce RTX 3090 Ti SUPRIM X 24G
- MSI GeForce RTX 3090 Ti SUPRIM 24G
- MSI GeForce RTX 3090 Ti GAMING X TRIO 24G
- MSI GeForce RTX 3090 Ti GAMING TRIO 24G
- MSI GeForce RTX 3090 Ti BLACK TRIO 24G
![Phanteks Glacier G3090Ti Gigabyte Water Block box contents](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-gigabyte-box-content.jpg.webp)
![Phanteks Glacier G3090Ti ASUS Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-asus-bock-backplate.jpg.webp)
Cooling Power
Naturally, for demanding graphics cards, you’ll need a waterblock that can keep up. The Phanteks Glacier G3090Ti is such a block. Bundled with a backplate for aesthetics and security, this waterblock has been expertly crafted for high-performance cooling. For starters, the copper coldplate fully covers the waterblock, to ensure it cools the vital components. As a result, it can draw heat away from all the critical areas efficiently. Thanks to the large cooling fin area, there is more conductive surface area to work with to enable increased heat transfer. Plus, the backplate is equipped with thermal pads that contact the RAM and VRM. Another tasty boost to the heat transfer!
The Phanteks Glacier G3090Ti utilises a high-flow design that improves the current of your entire water-cooling system. With the waterblock, itself, being manufactured from premium acrylic, the resistance is greatly reduced, which allows your liquid coolant to flow more freely. Thus improving how efficiently heat is drawn away from your graphics card.
![Phanteks Glacier G3090Ti MSI Water Block DRGB lighting](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-msi-drgb.jpg.webp)
As a cheeky bonus, a syringe of Phanteks PH-NDC thermal compound has been included, to optimise contact between waterblock and graphics card. Phanteks has thought of everything.
Premium Materials
With the Phanteks Glacier G3090Ti Waterblocks, it’s more than just the design that enhances thermal efficiency. Its material make-up also bolsters the cooling potential. Only the most premium materials have been included with these waterblocks.
Firstly, the coldplate is manufactured from 100% pure copper, which is then nickel-plated, creating a sleek backdrop for the DRGB lighting. Copper is chosen for its incredible thermal capacity and conductive properties, making it an ideal material for heat transfer! Next, the casing is made of high-quality cast acrylic. Transparent and durable, this is the perfect showcase for coloured coolant and also helps the DRGB lighting to shine through.
Providing structure and support, the backplate is manufactured from CNC machine aluminium. The finish varies between the different coloured models, either chrome-plating or black anodised. Both finishes are elegant and add to the minimalist overall design of the Phanteks Glacier G3090Ti Waterblocks. Lastly, these waterblocks are fitted with VITON o-rings, which keep your water-cooling loop water-tight. What’s more, these are the preferred o-ring of the automotive and aerospace industries. A true mark of premium quality!
![Phanteks Glacier G3090Ti ASUS Water Block coolant](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-asus-coolant.jpg.webp)
![Phanteks Glacier G3090Ti Gigabyte Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-gigabyte-waterblock.jpg.webp)
DRGB Lighting
Each model is illuminated by DRGB lighting. The blocks contain fifteen LED dies that can be connected to your Phanteks DRGB case or compatible motherboard and controllers. Additionally, this product can be daisy-chained to expand your RGB setup. From there, you can synchronise all your devices to create a phenomenal light show.
![Phanteks Glacier G3090Ti Gigabyte Water Block DRGB lighting](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-gigabyte-drgb.jpg.webp)
Available Now
Do you need to keep your hefty Nvidia GeForce RTX 3090 Ti cool? Well, now you can. The Phanteks Glacier G3090Ti Waterblocks are available to pre-order at Overclockers UK. Will you go cool chrome or classic black?
- Waterblock and backplate bundle
- Designed for ASUS 3090 Ti GPUs
- Premium-quality materials
- High-flow design
- DRGB lighting
![Phanteks Glacier G3090Ti ASUS Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-asus-bock-backplate-chrome.jpg.webp)
![Phanteks Glacier G3090Ti Gigabyte Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-gigabyte-waterblock-black.jpg.webp)
- Designed for Gigabyte 3090 Ti GPUs
- High-flow design
- DRGB lighting
- Designed for MSI 3090 Ti GPUs
- High-flow design
- DRGB lighting
![Phanteks Glacier G3090Ti MSI Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/phanteks-glacier-g3090ti-msi-block-backplate.jpg.webp)
wow…
