This AIO cooler marks the debut for PHANTEKS in this sector. The Glacier One offers the complete package: an elegant design with high-quality workmanship, powerful components and quiet operations.
It is rounded off by digitally addressable RGB lighting and an effective infinity mirror.
One cooler to rule them all
These water coolers are available with black radiators in sizes 240, 280 and 360 mm. The white 240 MPH version also comes with two PHANTEKS Halos fan frames, which highlight the rotor blades of the fans with their D-RGB lighting. This means that the right cooling is available for every system and every requirement.
The coolers’ aluminium radiators have a high fin density of 21 FPI and thus offer particularly effective cooling despite a small surface area. This means that sufficient cooling is available even for the hottest of processors.
The PWM control system adjusts the pump speed to the load required Thus, a quiet and performant operation is always guaranteed. The 120 mm fans from the PHANTEKS MP PWM series are also controlled by a PWM signal. With their large fan blades, they are optimized for high static pressure and transport proper air through the fins of the radiator.
The visual highlight of the PHANTEKS Glacier One all-in-one water coolers is undoubtedly the pump housing’s lid. It is equipped with RGB lighting and an infinity mirror. This combined with the 14 digitally addressable RGB LEDs creates fantastic effects. Lighting can be controlled with a PHANTEKS RGB controller or with the software of a compatible motherboard.
The lid is magnetically attached to the radiator-pump combo. After installation, it is simple to attach and conceal the suspension mechanism to ensure a particularly clean look.
Due to the compact design of the cooler-pump combination with a height of only 41 mm and the angled hose connections, the Glacier One complete water cooling systems are highly compatible with motherboards, RAM modules and other components.
Want to Learn more about the PHANTEKS Glacier One AIO?
If you are interested in learning more about this unique product why not check out our latest post on the Forum or even head over to the dedicated landing page?
