Phanteks is launching multiple upgrades to their line-up including the Glacier R220C, so you’ll be ready for this year’s latest hardware releases. With these enhancements, you’ll be able to add performance, utility, and style to your gaming PC.
![Phanteks Glacier R220C Pump Combo banner image](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/230116-Glacier-R220-DDC-Reservoir-Category-1024x222.jpg.webp)
Keeping it Cool with the Glacier R220C Combo
First out of the gate is Phanteks’ new pump and reservoir combo, the Glacier R220C. This innovative combo, features a powerful 20W DDC pump pre-installed within the reservoir and sealed with a Viton rubber O-Ring to guarantee your coolant stays inside the loop. This pump provides ample water pressure to move your coolant around even the most complex of custom cooling loops.
![Phanteks Glacier R220C combo](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/R220C_Reservoir_Pump_Combo_02-300x300.jpg)
The reservoir contains several innovations that ensure your cooling is highly efficient. This includes a unique internal design, that facilitates trapping any air that may manage to work its way in. This aids in improving the efficiency of your cooling, and also supports in extending the life of the pump.
In addition to this, the reservoir can be easily mounted to a 120, 140-mm fan, or even to a radiator, which adds an extra front to dissipate heat from the system.
Finally, Phanteks is keeping things stylish with this combo, thanks to an all-transparent acrylic construction. This allows you to see your coolant flowing through the reservoir, for a mesmerising effect. Adding to this visual feast, Phanteks has also included RGB, with 18 DRGB LEDs fully integrated into the body of the reservoir.
![Phanteks Glacier R220C combo with RGB](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/R220C_Reservoir_Pump_Combo_03-300x300.jpg)
These can easily be controlled by utilising a compatible motherboard, via user-friendly apps such as ASUS Aura Sync, MSI Mystic Light, and RAZER Chroma.
Phanteks wants you to show off that GPU
So, your cooling system looks fantastic, but what about the rest of your PC? Well, Phanteks also has you covered when it comes to making your GPU the star of your computer. They have released their latest lines of Vertical Mounting Kits and Riser cables.
![Phanteks vertical GPU mounting kit](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/Phanteks-GPU-bracket-300x167.jpg)
The Phanteks Vertical GPU Mounting Kit is a bracket designed especially for the Eclipse P300A, P360A, and P400A chassis. However, it’s simple to adapt any Phanteks ATX-sized chassis to accommodate the kit.
This bracket, with its 4-slot design, is large enough to accommodate even the largest of GPUs, including an NVIDIA 4090. In addition, these kits also include a 220mm PCIe Gen 4.0 cable, which is perfect for handling high-bandwidth data.
For the enthusiast who desires PCIe Gen 4.0 speeds but does not require a bracket, such as when constructing a gaming PC in a small form factor chassis. Phanteks has a solution for that too, with their line of stand-alone PCIe Gen 4.0 riser cables.
![Phanteks PCIe Gen 4.0 Riser Cable](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/Phanteks-Gen-4-Riser-Cable-300x300.jpg)
All of the Phanteks cables feature high flexibility, perfect for getting your GPU exactly where you want it. Alongside this, each lane on these cables is individually shielded from EMI to reduce data corruption, no matter where your GPU might be situated.
Get your Phanteks Upgrades Today
So, take a leap and order/pre-order yourself some of these amazing PC upgrades today at Overclockers UK.
![Phanteks R220C combo box contents](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/R220C_Reservoir_Pump_Combo_08-300x300.jpg)
Phanteks Glacier R220C Combo
- Pump and reservoir combo
- 20W DDC Pump
- 200ml Reservoir
- Transparent acrylic construction
- D-RGB LED lighting
- Vertical Mount for GPU
- Compatible with most Phanteks ATX Chassis
- Compatible with 4 slot graphics cards
- 220mm riser cable included
- PCIe Gen 4 compliant
![Phanteks vertical GPU mounting kit box contents](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/Phanteks-GPU-bracket-kit-300x167.jpg)
![Phanteks PCIe Gen 4.0 riser cable box contents](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/Phanteks-riser-cable-box-300x167.jpg)
Phanteks GPU Riser Cable
- Highly flexible cables
- Ideal for vertical mounting GPUs or SFF builds
- Shielded from EMI
- Range of lengths available
