Introducing the Shift and Shift X, a small form factor duo that is perfect for any surrounding. A new level of premium, with dual aluminium and tempered glass panels with watercooling support.
Small and elegant, perfect for AIO cooling – with a bold, simplistic design that works in any space without the compromise on hardware. Both models are available in Gunmetal Grey and Satin Black finishes, giving a subtle and understated look which fits right at home as a media centre or under-tv system just as much as a gaming rig!
Evolv SHIFT
Phanteks Evolv SHIFT Satin Black ITX Case
  • Measurements: 170 (w) × 274 (d) × 470 (h) mm
  • Clearance: 82mm (CPU), 350mm (GPU), 55mm (Bottom Rad)
  • Radiator Support: 120mm (Front), 120mm (Bottom)
  • Drive Support: 1 × 3.5″, up to 3 × 2.5″
Evolv SHIFT-X
Phanteks Evolv SHIFT-X Gunmetal Grey ITX Case
  • Measurements: 170 (w) × 274 (d) × 650 (h) mm
  • Clearance: 82mm (CPU), 529mm (GPU), 80mm (Front Rad)
  • Radiator Support: Up to 280mm (Front), 120mm (Bottom)
  • Drive Support: 2 × 3.5″, up to 4 × 2.5″
0 0 votes
Article Rating
Subscribe
Notify of
guest
1 Comment
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
David Corden
David Corden
7 years ago
Awesome case, can’t wait to custom cool it!
