Premium engineering, improvement and innovation. The Phanteks Enthoo Elite.
Taking advantage of modular design and superior materials, Phanteks Enthoo Elite is the latest chassis for the high-end market, delivering a housing that’s built to house the the highest of enthusiast components. Allowing for two discrete systems to be contained within the same chassis, the Enthoo Elite allows users to install a large system measuring E-ATX form factors at the largest or Mini-ITX form-factors at the smallest to be installed within its main chamber, along with a Mini-ITX system to be held within the lower.
Giving way for a third standalone chamber for cable management and the main system’s power supply, this Tri-system design is the first of its unique design, providing a clean and efficiently designed layout so that the final build is striking as it is hassle-free. Taking note of the current market trends, the Enthoo Elite revolutionizes the idea of compartmentalised design and modularity, giving its competitors something to learn from. Allowing users to do away with the secondary system for a single build, the lower unit can be removed in place of additional radiators and additional storage – giving way for a maximum of x13 3.5 inch drives and x6  2.5 inch drives, largely in part to its removable plates and simple means of hardware layout.
Featuring native support for both vertical and horizontal GPU mounting, the Enthoo Elite allows for a wide range of watercooling options, with substantial amount of clearance for however the user wishes to build their system. Allowing for radiators up to 480mm in length to be installed within the front, top, bottom as well as the convertible midplate within the chassis, with 360mm in the side of the lower compartment and a 120mm in the rear – watercooling enthusiasts will no doubt be pleased with Phantek’s emphasis in catering to the most extreme of builders. Along with pre-fitted pump brackets and reservoir sheaths, should users choose to opt for less watercooling equipment, the removable plates allow for additional fittings catering to cable management and additional storage drives.
Available for pre-order on the 5th January the Phanteks Enthoo Elite will be priced at £799.99 in colours options of Satin Black and Anthracite Grey. Making its first debut during CES 2017 the Enthoo Elite will be the new home to the world’s most powerful consumer PC – the 8Pack OrionX, launching on the 27th January.
CASE SPECIFICATIONS:
Dimension: (WxHxD)270 mm x 750 mm x 615 mm10.6 in x 29.5 in x 24.2 in
Form Factor: Extreme Full Tower
Materials: Anodized aluminium panels. Powder coated steel chassis. Tempered glass side panel
MB Support: E-ATX, ATX, Micro-ATX, Mini ITX, EEB
Front I/O: x4 USB 3.0, x2 Mic, x2 Headphone, x2 Reset button, RGB control wheel, HDMI 2.0, USB 3.1 Type-C
Side Window: Yes, Tempered  glass
PCI SLOTS & DRIVE BAYS: PCI slots 10 Internal 3.5” x13 (6 included) Internal 2.5” x6 (4 included)
FAN: 120 mm – Front x4, Top x4, Bottom x4, Midplate x3, Side x3, Rear x2
140 mm – Front x4 ( 3 installed), Top x3 ( 1 installed), Bottom x3, Midplate x3, Side x2, Rear x2 ( 1 installed)
RADIATOR: 120 mm – Front up to 480mm, Top up to 480mm, Bottom up to 480mm, Midplate up to 480mm, Side up to 360mm, Rear up to 120mm.
140mm – Front up to 560mm, Top up to 420mm, Bottom up to 420mm, Midplate up to 420mm, Side up to 280mm, Rear up to 140mm.
INCLUDED ACCESSORIES:
Premium fan 140 mm
x5 PWM fan hub
x2 Pump bracket
x2 3.5” modular HDD bracket x6
2.5” SSD bracket x4
Closed top panel x1
Radiator side panel x1
Vertical GPU bracket x1
Power splitter bracket x1
Dual system bracket x1
5.25” ODD bracket x1
Side panel dust filter x1
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
