Dutch manufacturer Phanteks adds a new model to its high-end Enthoo range of PC cases. Now there is an Enthoo case to suit multiple requirements and price points.
The Enthoo Pro 2 however has some unique features to differentiate it from the others. For one thing, it features a ‘High-Performance Fabric’ mesh front panel. Building a powerful Gaming PC will of course generate a high thermal load. The fabric solution Phanteks offers not only looks great but enables superior airflow filtration over metal or plastic front panels.
Extensive interal capacity for components
The internal capacity of the Enthoo Pro2 is also impressive. It can hold up to SSI-EEB motherboards (305mmx330mm) and when combined with the Revolt X or Revolt Pro, it can be set up as a dual system. Also there are multiple storage configurations possible with up to eleven SSDs and four HDDs or up to three SSDs and twelve HDDs. There is equally great variety in the amount of fans and water cooling radiators that can be fitted
Traditional case design meets modern LED illumination
Phanteks offers the Enthoo Pro 2 in two variants. The core option includes a tempered glass side panel, which enables users to display components they’ve fitted inside the case. Indeed it is possible to mount your GPU vertically with an additional riser (sold separately). This variant also features buttons on the i/o panel to adjust LEDs’ colour and modes software-free.
The second variant is a closed case i.e. it doesn’t have a tempered glass side panel. This should be suitable for users who want a more traditional PC case and it highlights the industrial design of the Enthoo Pro 2
