Phanteks are back with a revolutionary Evolv Shift XT Mini-ITX PC chassis and their ever-popular Revolt line of PSUs.
![Evolv Shift XT Silver PC Chassis](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Galaxy_Silver_1.jpg)
Both the Mini-ITX Evolv Shift XT and Revolt SFX PSUs might be small in size but pack a whole host of enthusiast features. The Evolv Shift XT Mini-ITX PC chassis have the unique ability to extend in size to three different configurations perfect for any hardware. What’s more, the Revolt SFX line of power supplies offer outstanding efficiency with 80 Plus Gold and Platinum ratings.
Phanteks Evolv Shift XT Mini-ITX PC Case
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Satin_Black_19-e1644941096212.jpg)
- Expandble Mini-ITX Chassis
- Built-In PCIe Gen 4 Riser Cable
- D-RGB Infinity Effect Mirror
- Available in Black and Silver
The Evolv Shift XT offers a truly jaw-dropping aesthetic, with both the silver and black variants being complimented by a D-RGB Infinity Effect mirror that increases in size as you adjust the chassis between its three configurations.
Compact
![Evolv Shift XT Black Compact Mode](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Satin_Black_18-e1644943098337.jpg)
![Evolv Shift XT Black Compact Mode](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Satin_Black_12-e1644943296505.jpg)
- 72mm CPU Air Cooler
- 3-Slot GPU up to 324mm Long
Even in the Phanteks Evolv Shift XT’s most compact configuration, there’s no need to compromise. You have plenty of space for ultra-performance components. In this mode, the chassis can support a triple slot GPU up to 324mm long, and even a 72mm tall CPU cooler.
Air Boost
![Evolv Shift XT Black Air CooledMode](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Satin_Black_191-e1644943145642.jpg)
![Evolv Shift XT Black Air Boost Mode](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Satin_Black_13-e1644943368119.jpg)
- 2 x 120 / 140mm Fans on top
In the Air Boost Configuration, the case extends to support two 120 or 140mm cooling fans, allowing for extra airflow. What’s more, in this mode the D-RGB Infinity Effect Mirror appears larger, perfect for upgrading your aesthetic.
Liquid Cooled
![Evolv Shift XT Black Liquid Cooled Mode](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Satin_Black_20-e1644943226498.jpg)
![Evolv Shift XT Black Liquid Cooled Mode](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Satin_Black_14-e1644943452219.jpg)
- 240mm AiO Liquid Cooler on top (60mm clearance)
Finally, in the largest configuration, the chassis is ideally suited for water-cooling with the height of this Mini-ITX PC case increasing to 272mm, providing an extra 31mm of space for a radiator and fans.
Despite the small package, the Evolv Shift XT features an awe-inspiring sleek design. This Mini-ITX PC case is sure to turn heads, thanks to the all-black or silver 2.5mm aluminium side panel construction alongside the iconic Evolv Series sleek modern styling. As part of the premium appearance, the case has a tempered glass front panel that houses the D-RGB Infinity Effect Mirror which increases in size as you change the chassis configuration.
![Evolv Shift XT PC case exploded view](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Evolv_Shift_XT_Satin_Black_8.jpg)
Revolt SFX PSUs
The perfect companion to the Evolv Shift XT chassis, Revolt SFX PSUs offer exceptional performance and enthusiast features.
![Revolt SFX 750 80 Plus Platinum PSU](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Revolt-SFX-750PSF-08-e1645004588198.jpg)
Phanteks Revolt SFX power supplies are available in 650W 80 Plus Gold, 750W 80 Plus Gold, and 750W 80 Plus Platinum configurations.
REVOLT SFX 650W GOLD
![Revolt SFX 750 80 Plus Platinum PSU](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Revolt-SFX-750PSF-01-e1645005233834.jpg)
- 650 Watt Modular SFX PSU
- 80 Plus Gold Certified
- 90% Efficiency at 50% load
- Zero RPM Mode – Ultimate Silence Below 30% load
REVOLT SFX 750W GOLD
- 750 Watt Modular SFX PSU
REVOLT SFX 750W PLATINUM
- 80 Plus Platinum Certified
- 92% Efficiency at 50% load
Thanks to their super-compact SFX size, the Revolt SFX series of PSUs are ideal for small form factor chassis. This power supply boasts a length of only 100mm, freeing up space for cable management and airflow. Additionally, the Revolt SFX is equipped with a silent Zero RPM mode allowing for ultimate silence below 30% system load.
Ready to Upgrade?
Are you planning to upgrade to a Mini-ITX chassis in 2022? Let us know in the comments below.
