Following on from the latest batch of Glacier waterblocks, Phanteks now offer a new version optimised for the Gigabyte Aorus RTX 3090/3080 Master/Xtreme GPUs.
As with other waterblocks in the Glacier line, the Phanteks Glacier G30 Aorus, has excellent build quality. It is available in two colours: a subtle black and eye-catching chrome. Both are perfectly complemented by the Glacier G30 Aorus’s integrated D-RGB, which shine through the acrylic top panel.
The Coolest Components
The Glacier G30 Aorus comes in a bundle with an equally premium backplate as well as the specific screws, thermal pads, and thermal compound you need to ensure excellent contact with the GPU. Additional VITON rub-seals – the same used in the automotive and aerospace industries – keep everything fully watertight.
The waterblock’s large surface and copper plating ensure excellent heat transfer. Liquid cooling not only offers improved performance but results in less noise compared to air cooled builds.
Take advantage of the benefits from watercooling for your GPU with the Phanteks Glacier G30 Aorus. Available now!
GLACIER G30 AORUS – Chrome
- Made for Gigabyte Aorus RTX 3090/3080 Master/Xtreme cards
- Manufactured from premium materials, including Aluminium, Copper and Nickel
- Stylish acrylic cover with integrated D-RGB
- Includes screws, thermal pads, and paste for improved thermal performance
GLACIER G30 AORUS – Black
