Merging minimalistic design with practical functionality, Raijintek has launched the PAEAN Benchtable.
Crafted from a black, hair-silk plate of fine aluminium the Raijintek PAEAN takes traits from most recent cases and marries the tempered glass trend to an open-bench format. Supporting up to x3 3.5″ drives along with x3 2.5″ inch drives, the PAEAN chassis utilises a dual-chamber layout to divide the power supply and storage compartments to a single area – opening up the opposing side for test-bed purposes. Not only does this create a unique and tidy layout, it’s also rather distinctive, making it appealing to gamers, modders and PC enthusiasts, along with an audience not so familiar – pertaining to art and design.
This unique quality that the PAEAN delivers not only looks attractive in use, but also when it’s out of use, reminiscent of futuristic sculpture. Providing support for standard ATX, M-ATX and M-ITX motherboards, along with graphics cards up to 400mm in length – extending multi-GPU support by the means of x8 PCI slots. The wide range of hardware configurations and physical sizing that the PAEAN delivers never compromises on looks, aligning watercooling support to a vertical format flat against the centre aluminium tray for a classy look.
The watercooling support that the PAEAN allows means that those who wish to use the benchtable as a standard chassis can do with ease, not to mention style. Giving way for radiators up to 360mm in length along with reservoir fitting, the PAEAN delivers more than enough clearance for tubing, and choices for full tower coolers should the user desire.
The Raijintek PAEAN is available now for £149.99
