We are proud to be stocking the Rajintek STYX. Based around the design of the Metis keeping similar aesthetics with the premium brushed aluminium crafted chassis design.
The STYX is noticeably larger comparing to the Metis, allowing you to install even more hardware. The case also supports 2x 120mm fans or a 240mm radiator in the top of the case and on the side, giving the user further cooling extending to high end air cooling or watercooling.
The case is 325mm in height, 360mm in length and 210mm in width. Giving the user space to install a graphics card up to a 280mm. The case also supports a 120mm fan at the back of the case, and at the bottom.
The additional features the STYX has over the Metis is that it can support a slim DVD drive allowing you to have a slot loading drive access on the right side of the case. The STYX is available in six colours, black, silver, red, blue, gold and green. Supporting Mini-ITX and Micro-ATX. The I/O ports are 2x USB3.0 and HD audio. Hard drive support is 3x 3.5” with 6x 2.5” drives allowing you to have a huge amount of storage.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
